buoyantSimpleFoam for HVAC application
Like Tree4Likes
  • 1 Post By tian
  • 1 Post By tian
  • 1 Post By Mojtaba.a
  • 1 Post By jaydeep
Old   July 8, 2012, 09:05
Lightbulb buoyantSimpleFoam for an HVAC application
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Hi.
I am using buoyantSimpleFoam for a simple HVAC system containing 4 air inlet on the ceiling and various forms of air outlet on the wall. There are 5 boxes in the room as a model for humans. there is a lamp producing a known amount of heat.
When i run the simulation after 3 iterations I got this error message:
| \\ / O peration | Version: 2.0.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : 2.0.1
Exec : buoyantSimpleFoam
Date : Jul 08 2012
Time : 17:03:33
Host : mojtaba-HP-Pavilion-dv5-Notebook-PC
PID : 25666
Case : /home/mojtaba/OpenFOAM/mojtaba-2.0.1/run/6_case1/RAS
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading g
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 -0.33;
sigmak 1;
sigmaEps 1.3;
Prt 1;
Calculating field g.h
Reading field p_rgh
SIMPLE: convergence criteria
field p_rgh tolerance 0.01
field U tolerance 0.001
field h tolerance 0.001
field "(k|epsilon|omega)" tolerance 0.001
Starting time loop
Time = 0.01
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.00330151, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0046823, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.00350567, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 1.39886e-06, No Iterations 1
DICPCG: Solving for p_rgh, Initial residual = 0.971915, Final residual = 0.00889702, No Iterations 33
time step continuity errors : sum local = 3.10455, global = -3.6689e-16, cumulative = -3.6689e-16
rho max/min : 1.3434 0.990723
DILUPBiCG: Solving for epsilon, Initial residual = 0.971289, Final residual = 0.0619395, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.033557, No Iterations 1
ExecutionTime = 1.21 s ClockTime = 1 s
Time = 0.02
DILUPBiCG: Solving for Ux, Initial residual = 0.127444, Final residual = 0.000790034, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.0886407, Final residual = 0.000657201, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.113225, Final residual = 0.000845678, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 0.435941, Final residual = 0.00537677, No Iterations 3
DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 0.00945094, No Iterations 638
time step continuity errors : sum local = 0.518813, global = -2.86768e-16, cumulative = -6.53658e-16
rho max/min : 1.97732e+10 -9.88007e+09
DILUPBiCG: Solving for epsilon, Initial residual = 0.605293, Final residual = 0.0131068, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.014658, No Iterations 2
ExecutionTime = 4.24 s ClockTime = 4 s
Time = 0.03
DILUPBiCG: Solving for Ux, Initial residual = 0.189338, Final residual = 0.00230566, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.153492, Final residual = 0.00222301, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.0758416, Final residual = 0.00080249, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 0.0792621, Final residual = 0.000120424, No Iterations 1
--> FOAM FATAL ERROR:
Maximum number of iterations exceeded
From function specieThermo<Thermo>::T(scalar f, scalar T0, scalar (specieThermo<Thermo>::*F)(const scalar) const, scalar (specieThermo<Thermo>::*dFdT)(const scalar) const) const
in file /home/mojtaba/OpenFOAM/OpenFOAM-2.0.1/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 67.
FOAM aborting
#0 Foam::error:: printStack(Foam::Ostream&) in "/home/mojtaba/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/mojtaba/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam::hPsiThermo<Foam:: pureMixture<Foam::constTransport<Foam::specieTherm o<Foam::hConstThermo<Foam:: perfectGas> > > > >::calculate() in "/home/mojtaba/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#3 Foam::hPsiThermo<Foam:: pureMixture<Foam::constTransport<Foam::specieTherm o<Foam::hConstThermo<Foam:: perfectGas> > > > >::correct() in "/home/mojtaba/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
in "/home/mojtaba/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/bin/buoyantSimpleFoam"
#5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Aborted
Any helps would be appreciated.
Mojtaba.a is offline   Reply With Quote
Old   July 9, 2012, 04:57
tian's Avatar
Tian
tian is on a distinguished road
check your boundary setup at time 0. It seems to be wrong.
Bye
Tian
Mojtaba.a likes this.
tian is offline   Reply With Quote
Old   July 9, 2012, 08:06
Mojtaba.a's Avatar
Originally Posted by tian View Post
Bye
Tian
Hi Tian,
Thanks for yout reply. my boundary conditions at time 0 are as follows:
For Pressure:
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 35e4;
boundaryField
wall
type calculated;
value $internalField;
air-inlet
type fixedValue;
value 2e5;
out_flow
type calculated;
patient
type calculated;
staff4
type calculated;
staff3
type calculated;
staff2
type calculated;
staff1
type calculated;
back_light
type calculated;
light
type calculated;
For Velocity:
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
wall
type fixedValue;
value uniform (0 0 0);
air-inlet
type turbulentInlet;
referenceField uniform (0 -1 0);
fluctuationScale (0.01 0.01 0.01);
value uniform (0 -1 0);
out_flow
type inletOutlet;
inletValue uniform (0 0 0);
patient
type fixedValue;
staff4
type fixedValue;
staff3
type fixedValue;
staff2
type fixedValue;
staff1
type fixedValue;
back_light
type fixedValue;
light
type fixedValue;
For Temperature:
FoamFile
version 2.0;
format ascii;
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 300;
boundaryField
wall
type fixedValue;
value uniform 298;
air-inlet
type fixedValue;
value uniform 293;
out_flow
type fixedValue;
value uniform 293;
patient
type fixedValue;
value uniform 307;
staff4
type fixedValue;
value uniform 307;
staff3
type fixedValue;
value uniform 307;
staff2
type fixedValue;
value uniform 307;
staff1
type fixedValue;
value uniform 307;
back_light
type fixedValue;
value uniform 298;
light
type fixedValue;
value uniform 298;
Model image:
Old   July 9, 2012, 08:26
tian's Avatar
Tian
T: out_flow
type fixedValue;
value uniform 293;
-- > Should be "zeroGradient" ?
P:
internalField uniform 35e4; ?
Is it not to much for a normal room?
air-inlet should be "zeroGradient" and out_flow also as fixedValue?
Bye
Tian
Old   July 9, 2012, 14:27
Mojtaba.a's Avatar
Do you mean I apply these changes in pressure 0 conditions? or all other conditions too?
And what do i assign as value to out_flow when I change it to fixedValue?
Old   July 9, 2012, 14:35
Mojtaba.a's Avatar
T: out_flow
type fixedValue;
value uniform 293;
P:
Bye
Tian
Final initial conditions are now as follows:
For Pressure:
FoamFile
version 2.0;
format ascii;
object p;
internalField uniform 1e5;
boundaryField
wall
type calculated;
air-inlet
type zeroGradient;
out_flow
type fixedValue;
value 1e5;
patient
type calculated;
staff4
type calculated;
staff3
type calculated;
staff2
type calculated;
staff1
type calculated;
back_light
type calculated;
light
type calculated;
For Temperature:
FoamFile
version 2.0;
format ascii;
object T;
boundaryField
wall
type fixedValue;
value uniform 298;
air-inlet
type fixedValue;
value uniform 293;
out_flow
type zeroGradient;
patient
type fixedValue;
value uniform 307;
staff4
type fixedValue;
value uniform 307;
staff3
type fixedValue;
value uniform 307;
staff2
type fixedValue;
value uniform 307;
staff1
type fixedValue;
value uniform 307;
back_light
type fixedValue;
value uniform 298;
light
type fixedValue;
value uniform 298;
For P_rgh:
FoamFile
version 2.0;
format ascii;
object p_rgh;
boundaryField
wall
type buoyantPressure;
air-inlet
out_flow
patient
staff4
staff3
staff2
staff1
back_light
light
For Velocity:
FoamFile
version 2.0;
format ascii;
object U;
boundaryField
wall
type fixedValue;
air-inlet
out_flow
type inletOutlet;
patient
type fixedValue;
staff4
type fixedValue;
staff3
type fixedValue;
staff2
type fixedValue;
staff1
type fixedValue;
back_light
type fixedValue;
light
type fixedValue;
But i face the same error message again.
raj kumar saini likes this.
Old   November 14, 2017, 16:28
Himanshu Sharma
himanshu28 is on a distinguished road
For Pressure:
For Temperature:
For P_rgh:
For Velocity:
Were you able to solve the problem. I am doing pretty much the same kind of the problem, and getting the same divergence.
Thank you
himanshu28 is offline   Reply With Quote
Old   November 16, 2017, 15:49
Jaydeep
jaydeep is on a distinguished road
As a thumb rule - you should not use explicit boundary conditions to Pressure in cht solvers.
p = p_rgh + rho*gh;
This is how pressure is handled in the solver.
Secondly - for free boundaries on pressure (atmospheric) ideally you should use totalPressure in p_rgh (updated version of buoyantPressure), although I have experienced instability with totalPressure and discovered zeroGradient to be working quite well.
Next - for inlet conditions, unless specified, I'd recommend "zeroGradient" at both inlets and outlets in velocity boundary condition.
jaydeep is offline   Reply With Quote
buoyantsimplefoam, hvac, openfoam
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
buoyantSimpleFoam samiam1000 OpenFOAM Running, Solving & CFD 0 February 22, 2012 08:20
Others library application for OpenFoam 1.5 in Windows lcnmy OpenFOAM Installation 2 July 21, 2010 20:54
Installation of OpenFOAM15dev antonio_ing OpenFOAM Installation 34 December 18, 2009 10:06
Running buoyantSimpleFoam with oodles data as initialisation samulu OpenFOAM 5 November 19, 2009 11:49
