Calculating Forces
Old   November 28, 2017, 13:59
Default Calculating Forces
Friendly is on a distinguished road
I intend to calculate the drag and lift on a body. Therefore I would like to know how OpenFOAM calculates those forces. I have no troubles to make the solver calculate thoses forces but I would like to interpret them and therefore I need to know how they are calculated.
In forces.C it appears, that OpenFOAM calculates a total force by integrating the pressure over a surface. The projection in a given direction is the drag force. But what about viscious drag?
Can anybody help me with that?
Friendly is offline   Reply With Quote
Old   November 30, 2017, 22:08
Lisandro Maders
Lisandro Maders is on a distinguished road
I took a quick look in the "forces.C" file and I think it should be something close to this:
In the "forces.C" file you will find the function
void Foam::functionObjects::forces::calcForcesMoment()
in which the pressure, viscous and porous forces are calculated separately. The viscous forces, for instance, are stored as a "vectorField", through an object called "fT" and it is calculated in its construction as follows:
vectorField fT(Sfb[patchi] & devRhoReffb[patchi])
Somewhere it should have a loop to sweep all surfaces from a given [patchId].
Hope it helps.
Regards, Lisandro Maders
Lisandro Maders is offline   Reply With Quote
Old   December 1, 2017, 06:26
Thank you very much, it does.
I have found this as aswell (and for fN aswell). I have two questions for the second line of code you have posted:
What excatly does "&" mean? And what is "Sfb"? B stands for boundary, but why excatly is Sf? I think it has to be the normal vector fo the surface times the are of the surface (surface of the face).
Help! problems in calculating forces with SimpleFoam DLC OpenFOAM 3 April 25, 2022 23:43
Problem calculating forces on blades 2 (for finding forces) bye bye my blue OpenFOAM Running, Solving & CFD 16 April 19, 2018 10:48
calculating forces from forceDensity achyutan OpenFOAM Running, Solving & CFD 0 August 6, 2013 07:37
Calculating forces on a non-closed surface ScottN FLUENT 0 March 1, 2011 17:18
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
