May 22, 2019, 06:47 |
Obtaining negative temperature sonicFoam
adrian chelaru
Rep Power: 11 |
Hello!
I am trying to simulate a Naca0012 profile, using the sonicFoam solver. My trouble is that I am obtaining a negative temperature and the solver crashes. Also, if I plot the residuals, the continuity equation shows negative values. Anyone has any ideas? I saw some posts with similar problems, but no result was found what so ever. I am also having troubles with setting my boundaries conditions. I am new in openFoam. My trouble is, what kind of boundary conditions should I set if I want to have a farfield like in Fluent? |
May 24, 2019, 00:53 |
tutorial case?
Will Kernkamp
Rep Power: 12 |
I usually start from a tutorial case. For sonicFoam look in compressible.
July 17, 2019, 14:58 |
Try and control cfl number using adjustable time step feature in OF
Dumbledore
Rep Power: 6 |
https://www.cfd-online.com/Forums/op....html#poststop
check this out Increase in courant number maybe the reason for blowup A same time step through out the simulation is not suitable During some iterations the demand for time step is very less due to flow characteristics in the domain and non robustness of the solver. so try to enable "adjustabletimestep" in controldict which can control time step and controls the steady increase in courant number add this lines in your controldict code: HTML Code:
adjustTimeStep yes; maxCo 0.7; maxDeltaT 0.01; You can also limit the degree of temperature value update after every iteration using relaxation factor for you energy equation. HTML Code:
relaxationFactors { fields { p 0.3; T 0.3; } equations { U 0.4; "(rho|k|nuTilda|e).*" 0.4; } } |
July 17, 2019, 15:04 |
Dumbledore
Rep Power: 6 |
https://www.openfoam.com/documentati...conditions.php
http://www.nextfoam.co.kr/lib/downlo...bb43ccfe025b25 Please go through these links and these might help you as a reference when you while you are stuck in defining boundary conditions. |
negative temperature, openfoam., sonicfoam |
Negative temperature and pressure in sonicFoam :O | gallon | OpenFOAM Running, Solving & CFD | 16 | January 21, 2019 05:56 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
Unexpected large decrease in Total temperature across the shock using sonicFoam | JLight | OpenFOAM | 0 | December 16, 2010 11:46 |
Unexpected large decrease in Total temperature across the shock using sonicFoam | JLight | OpenFOAM Running, Solving & CFD | 0 | December 15, 2010 05:47 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
