Smagorinsky Problem - LES - Internal pipe flow |
December 29, 2017, 11:41 |
#1 | |
Guilherme
Rep Power: 10 |
I am performing a simulation in internal flow (simpleFoam - steadyState - RANS and LES). I was based on the model: tutorials/incompressible/pisoFoam/LES/motorBike I modified the code so that when simulation in RANS reaches convergence (and there is no problem with it), the simulation would continue in LES (for that reason the log.simpleFoam below starts at time 700). By evaluating the log, one realizes that the calculation of 'k' is not happening... why? can anybody help me? The directory 0 contains: U, p, nut, and k. Quote:
December 29, 2017, 11:56 |
Uwe Pilz
Rep Power: 15 |
It si not a good idea to start a simulation in RANS and use the values for k and epsilon/omega to LES. They have another meaning there and differe remakably form the RANS values.
Is there a important reason not to start with LES?
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
December 29, 2017, 17:54 |
Hi
#3 | |
Guilherme
Rep Power: 10 |
I figured that because I was using the Smagorinsky model ... which needs the 'U', 'p', 'k' and 'nut' files. I did not think it would be important to use RANS earlier, since the tutorial also uses it. I am believing that the problem is occurring because I used steadyState (fvSchenes) for LES. I believe that this is not right. |
Flow regime for internal pipe flow | sisetrun | OpenFOAM Running, Solving & CFD | 0 | November 3, 2016 07:21 |
Two-phase flow in a circular horizontal pipe | DmitryS | Fluent Multiphase | 0 | May 17, 2014 16:22 |
Laminar Circular pipe flow problem | GLee | CFX | 6 | September 15, 2011 10:57 |
No Fluctuatios in LES results for pipe flow!!! | Roohi | CFX | 5 | September 7, 2011 18:50 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
