Solver hangs due to different decomposition methods - reactingFoam. |
July 27, 2020, 07:32 |
ssa
Rep Power: 7 |
Hi all,
I have a strange problem with our in-house solver. The solver was built from reactingFoam in OF2.4x to solve the chemistry only at required cells based on the Temperature with PaSR combustion model and GRI 3.0 mechanism. The solver runs smoothly in serial, there is no error. When I switch to parallel with scotch decomposition, it hangs at somepoint. When I use simple decomposition, For ex. (1 60 1) it hangs at a time of 4.08e-5 and with (1 32 1) it hangs at 4.17e-5. But when I change the decomposition to (2 7 2) it runs smoothly. There is no error from the terminal. It just hangs and no message further. I want to increase the number of cores to 60, But the maximum I could use now is 28. The simulation is a simple burner simulation with methane and oxygen at inlet with a mesh size of around 6.5 million cells. Does anyone face similar errors with reactingFoam solver. Thanks, Senthil. |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 15:44 |
CAMWA special issue on open-source numerical solver | feixu2019 | SU2 News & Announcements | 0 | October 1, 2018 11:19 |
comments on FDM, FEM, FVM, SM, SEM, DSEM, BEM | kenn | Main CFD Forum | 2 | July 18, 2004 18:28 |
