January 15, 2018, 04:32 |
Boundary condition for a porous wall
Deep
Rep Power: 8 |
Good morning!
I want to use "buoyantBousinessqSimpleFoam" for a problem involving porous medium. There is a porous wall as one of the domain boundaries over which there is flow. However, I want to define this porous wall as an inlet as well (since it is porous assuming I can find the outlet conditions of flow through the porous medium, which then can be kept outside of the domain). So that would mean there will be two inlets one the usual and the other through the porous wall. What is the best boundary condition for such a porous surface? Is there any way I can use a "wall" as well as a "velocity inlet" boundary condition to it? How? Thanks |
September 25, 2022, 05:21 |
Hello Deep,
I hope you are doing fine. I am also searching for a similar kind of boundary condition. Can you help me out with this if you have already resolved this problem? Thanks and regards |
boundary conditions, porous boundary |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 08:16 |
Porous wall boundary condition in LES | Henrik | FLUENT | 0 | May 31, 2007 06:17 |
