February 26, 2018, 08:31 |
simpleFoam exits with error
Sean Gorry
Rep Power: 8 |
I am running a simulation of turbulent flow through a fluid domain. When I got to run simpleFoam, the solver starts, buts stops before any iterations. I am running the solver in parallel and I get an exit code 142.
Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 1e-06 field U tolerance 1e-06 field "(k|epsilon|omega)" tolerance 1e-06 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave bounding k, min: 0 max: 0 average: 0 bounding omega, min: 0 max: 0 average: 0 RAS { RASModel kOmegaSST; turbulence on; printCoeffs on; alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; decayControl false; kInf 0; omegaInf 0; } No MRF models present Creating finite volume options from "system/fvOptions" Selecting finite volume options type limitVelocity Source: Fluid_Domain - selecting cells using cellZone fluid_domain - selected 1570686 cell(s) with volume 5.18396e-06 ------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code.. Per user-direction, the job has been aborted. ------------------------------------------------------- -------------------------------------------------------------------------- mpirun detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[10353,1],7] Exit code: 142 -------------------------------------------------------------------------- |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
