March 5, 2018, 12:39 |
Which solver to use ?
Adrien
Rep Power: 8 |
Hi Foamers,
I have a small quizz for ya. Considering that I can do: - a multiphase heat transfer using chtMultiRegionFoam (ie: liquid/liquid exchanger) - a boiling simulation with reactingTwoPhaseEulerFoam Is there a way to do BOTH at the same time ? Put clearly, can OpenFOAM simulate hot pressurised water in a copper tube that will evaporate unpressurized water around it ? Good evening everyone |
March 5, 2018, 16:53 |
Tobias Holzmann
Rep Power: 51 |
that is not a quiz. Yes you will be able to do that with foam but not with the standard libraries and solvers. You have to program it yourself. Good luck for that topic.
Keep foaming, Tobias Holzmann |
March 6, 2018, 02:00 |
Adrien
Rep Power: 8 |
Hi Tobias,
Thank you for your answer, and for your overall contribution, it's somehow because of you that I'm fond of OF today. I'll dig the question. The handtaylored solver for boiling simulation I found so far (here: https://www.youtube.com/watch?v=trZIxYIH7-0) seems to imply out of date code. Well, it's never easy. You're right, so I have another question Is a fluid model plasma modelling also possible on OpenFOAM ? Does it imply to manually write maxwell and transport equations in a custom solver ? If so, is there a course somewhere that describe this kind of process ? Cheers |
March 6, 2018, 09:36 |
Tobias Holzmann
Rep Power: 51 |
actually I am doing the same development in my programming screen casts (with respect to the source given in the video » Chalmers). See 5.6 on my website (https://holzmann-cfd.de/training/ope...nd-programming). Actually the only difference is the adding of a passive transport equation for the temperature and add a temperature depended saturation pressure, e.g. a formulation given here https://en.wikipedia.org/wiki/Vapour_pressure_of_water. However, some remarks to the video:
To your other question. Plasma modeling is possible sure. One colleague in the chair I am working at is doing that (ANSYS). However, there should not be a problem to do the same stuff with FOAM. In addition another colleague is duing MHD. However, I cannot give you any advice which equations have to be modeled and taken into account for plasmas. If I remember correctly my colleague calculates free iones in the air and other things - complex modeling but the results look exciting <3. If you need all the Maxwell equations, I don't know. Depend what your want to model. One thing to your first post. I would write a new solver that solves a CHT problem with 1 solid, 1 singlephase and 1 multiphase domain. Good luck Tobi PS: Thanks for your words. I feel honored if you get used to FOAM based on my work. Actually, we should thank Bruno who is keeping the forum clear and also do a lot of work here as well as Bernhard for the wiki. Of course there are a lot of other guys who should be acknowledged. I took my time and did it now: Thanks to the people who are making this forum successful
Fluent Adjoint Solver? | ex10148 | FLUENT | 16 | September 28, 2018 08:11 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 05:03 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 06:58 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
