k-OmegaSST: Wallfunctions or not?
Old   March 6, 2018, 06:48
Default k-OmegaSST: Wallfunctions or not?
kaaja is on a distinguished road
I am running k-omegaSST, and I am really confused about wallfunctions. The more I read about it, the more confused I get. I have some questions I hope someone can help me with:
1) K-omega is meant to be solved without wall-functions, so yPlus should be < 1?
2) omegaWallFunction is really not a wallfunction (it is applied for yPlus < 1, and then wallfunctions should not be used)?
3) If for some reason k-Omega is solved with yPlus > 1, nutLowReWallfunction must be applied?
4) k-OmegaSST is a mix of k-epsilon and k-omega?
5) The idea of kOmegaSST is to use k-omega close to the wall and k-epsilon far from the wall?
6) Since k-omega is used close to the wall in k-omegaSST, one should use omegaWallFunction if yPlus < 1.
7) Since k-omega is used close to the wall in k-omegaSST, one should use nutLowReWallFunction if yPlus > 1.
8) With kOmegaSST and yPlus < 1, what shall one use as wallBC in for Nut?
9) With kOmegaSST and yPlus < 1, what shall one use as wallBC in for k?
10) nutSpladingWallFunction is meant to be used when running kOmegaSST and 30 < yPlus < 200 (the standard wallFunction range I think)?
11) The similarity between nutSpladingWallFunction and nutLowReWallfunction is that both are used for yPlus > 1?
12) The difference between nutSpladingWallFunction and nutLowReWallfunction is that the former is used for kOmega and the latter is used with kOmegaSST?
kaaja is offline   Reply With Quote
Old   March 6, 2018, 10:18
Andrew Coughtrie
Andrew.Coughtrie is on a distinguished road
As an example look at the simpleFoam motorBike case in OpenFOAM-1712.
kqRWallFunction for k
omegaWallFunction for omega
Read the following paper which explains the kOmegaSST wall treatment
Esch, T., & Menter, F. R. (2003). Heat Transfer Predictions based on Two-Equation Turbulence Models with Advanced Wall Treatment. In Turbulence, Heat and Mass Transfer 4.
Additionally OpenFOAM now defaults to a switching rather than blended treatment for omegaWallFunction based on improved accuracy at higher y+ values.
Andrew
Andrew.Coughtrie is offline   Reply With Quote
yPlus and wallfunctions in rotating walls Yuby OpenFOAM Running, Solving & CFD 1 April 20, 2015 11:32
Scalable wallFunctions openFOAM? Hekky OpenFOAM Running, Solving & CFD 0 November 5, 2013 08:00
problem with wallFunctions (kEpsilon model) dinonettis OpenFOAM 12 April 22, 2010 21:37
decompose with wallfunctions linnemann OpenFOAM Running, Solving & CFD 4 October 16, 2009 06:41
Regarding wallFunctions Hectux OpenFOAM Running, Solving & CFD 0 May 29, 2009 03:23
