Simulation stops with high courant number
Old   January 25, 2020, 14:43
Default Simulation stops with high courant number
Victor
Victor3 is on a distinguished road
Hi
I'm trying to learn OpenFOAM again after being away for a while. I've modified the icoFoam/elbow example with my own mesh. But It stops after a short while. The geometry is just a simple rectangle for testing.
control dict:
application     icoFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         6;
deltaT          0.005;
writeControl    timeStep;
writeInterval   20;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
0/U:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    wall
        type            noSlip;
    inlet
        type            fixedValue;
        value           uniform (0.01 0 0);
    outlet
        type            zeroGradient;
Showing the end:
Courant Number mean: 0.79581 max: 63.1
smoothSolver:  Solving for Ux, Initial residual = 0.685782, Final residual = 9.41785e-06, No Iterations 66
smoothSolver:  Solving for Uy, Initial residual = 0.716174, Final residual = 8.69162e-06, No Iterations 63
smoothSolver:  Solving for Uz, Initial residual = 0.693323, Final residual = 8.51979e-06, No Iterations 59
DICPCG:  Solving for p, Initial residual = 0.713553, Final residual = 0.0356645, No Iterations 156
DICPCG:  Solving for p, Initial residual = 0.338417, Final residual = 0.0123583, No Iterations 3
DICPCG:  Solving for p, Initial residual = 0.033877, Final residual = 0.00167932, No Iterations 170
time step continuity errors : sum local = 0.00694275, global = 0.000103744, cumulative = -9.99947e-05
DICPCG:  Solving for p, Initial residual = 0.129921, Final residual = 0.00645082, No Iterations 151
DICPCG:  Solving for p, Initial residual = 0.25175, Final residual = 0.00949852, No Iterations 3
DICPCG:  Solving for p, Initial residual = 0.0337265, Final residual = 9.34626e-07, No Iterations 211
time step continuity errors : sum local = 3.23715e-06, global = 1.79642e-08, cumulative = -9.99768e-05
ExecutionTime = 24.94 s  ClockTime = 26 s
Time = 0.315
Courant Number mean: 1.13275 max: 119.556
smoothSolver:  Solving for Ux, Initial residual = 0.684699, Final residual = 9.86724e-06, No Iterations 104
smoothSolver:  Solving for Uy, Initial residual = 0.703938, Final residual = 9.742e-06, No Iterations 107
smoothSolver:  Solving for Uz, Initial residual = 0.690446, Final residual = 9.77228e-06, No Iterations 131
DICPCG:  Solving for p, Initial residual = 0.674098, Final residual = 0.0325922, No Iterations 151
DICPCG:  Solving for p, Initial residual = 0.357341, Final residual = 0.0124241, No Iterations 3
DICPCG:  Solving for p, Initial residual = 0.0348905, Final residual = 0.00174187, No Iterations 170
time step continuity errors : sum local = 0.00968451, global = 2.81742e-05, cumulative = -7.18026e-05
DICPCG:  Solving for p, Initial residual = 0.12856, Final residual = 0.00636255, No Iterations 147
DICPCG:  Solving for p, Initial residual = 0.266371, Final residual = 0.00985169, No Iterations 3
DICPCG:  Solving for p, Initial residual = 0.0348542, Final residual = 9.78138e-07, No Iterations 211
time step continuity errors : sum local = 4.60704e-06, global = 1.03763e-08, cumulative = -7.17922e-05
ExecutionTime = 25.42 s  ClockTime = 26 s
Time = 0.32
Courant Number mean: 1.16594 max: 69.504
Victor3 is offline   Reply With Quote
Old   January 28, 2020, 17:35
Svetlana Tkachenko
Светлана is on a distinguished road
I would suggest to upload the entire case so that others can see your geometry and mesh.
Светлана is offline   Reply With Quote
Old   January 29, 2020, 11:49
Peter Hess
peterhess is on a distinguished road
deltaT seams to be very high!
Either reduce deltaT to about 0.00005.
Or
add those two lines to controlDict:
maxCo 1;
adjustTimeStep yes;
Or (better):
do both at the same time!
Like that the solver will start with a low Co. and modefi deltaT as it need to keep Co under 1!
What checkMesh tells? Is your mesh ok?
Regards
Peter
peterhess is offline   Reply With Quote
beginners, courant number increasing
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 21:00
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 14:49
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 14:53
