March 8, 2018, 13:36 |
Non-Physical Result in MRF simpleFoam
Chaz
Rep Power: 14 |
I am getting a non-physical velocity result, and often the solution diverges. The odd thing to me is that the huge velocity appears on the boundary, which should be held at U=0 by the BCs. Image attached. Problem is a mixer type problem, with an inner rotor spinning in a moving reference frame, surrounded by a fixed reference frame. AMI used for boundaries. Setup is based on several examples. simpleFoam steady solution. Divergence is at the x=max, z=max point. The problem persists for U=0 BCs as well as U=slip on the outside of the stator region. Mesh was generated in Salome using Netgen 1-2-3 with viscous layers. Problem persists without viscous layers, as well as using mefisto 2D + netgen for 3D, but the divergence now occurs at Y=max point. Any ideas what is going on? |
MRF solvers give diffenrent results when MRF zone's diameter is different | sharonyue | OpenFOAM Running, Solving & CFD | 10 | May 31, 2022 04:46 |
BC for MRF simpleFoam | student666 | OpenFOAM Running, Solving & CFD | 2 | July 30, 2014 13:20 |
simpleFoam - Change physical properties of liquid | vut | OpenFOAM Running, Solving & CFD | 4 | March 6, 2014 04:32 |
Physical model: MRF RANS | Ruli | OpenFOAM Running, Solving & CFD | 4 | February 17, 2014 06:14 |
Partition does not start on physical sector boundary!!?? | immortality | Lounge | 1 | December 8, 2013 15:04 |
