How to set initial conditions for LES 3D case?
Old   March 20, 2018, 21:29
Default How to set initial conditions for LES 3D case?
Derek
Derek2580 is on a distinguished road
Still doing unsteady flow past 3D cylinder. Can someone advise how to set initial conditions for LES 3D case?? Or if you could provide any similar tutorial. Much appreciate!
Initial conditions includes: k, nut, nuTilda, p and u (btw, is "s" necessary for LES?
Derek2580 is offline   Reply With Quote
Old   March 21, 2018, 01:12
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
I use:
k: Fixed value 0.1 nearly everywhere, kqRWallFunction at a surface of interest
nut: calculated nearly eveyrwhere, nutkWallFunction at a surface of interest
p: zeroGradient nearly everywhere, a fixed value at one of the patches
I don't need much more for the dynamicKEqn model.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 21, 2018, 23:07
Derek
Thank you Sir!
Old   March 30, 2018, 11:38
Derek
sir, will the initial k and nut significant affect the calculation results?
Old   March 30, 2018, 12:25
piu58's Avatar
Uwe Pilz
In any case it influences how fast and stable the simulation starts. But you may try this out for your case.
Uwe Pilz
Old   April 22, 2018, 02:41
JD
dickcruz is on a distinguished road
Originally Posted by piu58 View Post
I use:
I always thought that the kqRWallFunction and nutKWallFunction were used only on cases with RAS for turbulence modelling. Is that not true?
So, with these wall functions in place, do you use 30<y+<300 ?
dickcruz is offline   Reply With Quote
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 17:36
Foam::error::printStack after large bounding epsilon events StoneCFD727 OpenFOAM Running, Solving & CFD 1 January 1, 2018 17:04
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
should Courant number always be kept below 1? wc34071209 OpenFOAM Running, Solving & CFD 16 March 9, 2014 19:31
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
