rising bubble simulation with interFoam
Like Tree2Likes
  • 1 Post By piu58
  • 1 Post By piu58
Old   March 27, 2018, 09:15
Default rising bubble simulation with interFoam
cyw
Yuanwei Cao
cyw is on a distinguished road
Dear all,
does anybody simulate a single bubble rising in quiescent liquid[1] with interFoam? I simulate several cases but I cannot repeat all the regions with interFoam. I mean the bubble shapes and paths can not match the published results in [1]. Or did I do something wrong?Attachment 62371 I have attached the case file, please help me!
[1] Sharaf, D. M., et al. "Shapes and paths of an air bubble rising in quiescent liquids." Physics of Fluids 29.12 (2017): 122104.
cyw is offline   Reply With Quote
Old   March 27, 2018, 09:51
cyw
Yuanwei Cao
Originally Posted by cyw View Post
Dear all,
The author of the paper uses gerris.
Old   March 27, 2018, 10:23
Hosein
einstein_zee is on a distinguished road
Hey there,
other than that there are many things which are different from your case. I looked at your case, first and foremost they have done a DNS simulation but you are using k-epsilon for turbulence modeling. moreover, they are solving their own derived equations which is different from the approach in OF. Also there might be differences in the discretization schemes and many more issues which all and all are leading to failure in your case.
einstein_zee is offline   Reply With Quote
Old   March 27, 2018, 10:27
cyw
Yuanwei Cao
Originally Posted by einstein_zee View Post
Hey there,
Thank you for your answer. The author of the papaer uses another openfoam source software gerris to simulate the case.
Old   March 28, 2018, 00:54
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Dear Foamers,
may be you know the very extended work of Hysing et alii which compares different approaches for calculation fo bubble dynmics. The case there is a 2D rising bubble of diameter 0.5 in a cuvette of width 1 and height 2, slip b.c. at the walls. Two different setups were used, one rather describing an oil bubble in water and another, numerical more challenging which is close to an air bubble in water.
In the paper three software packages were used, all FEM codes. In a picture, some examples were shown for CFX, Comsol and Fluent, but no real numeral results for these codes. OpenFoam was not used.
The authors found two measures which describe the solution all in all: The center of mass, maximum rise velocity and the "circularity" which describes deformations mathematical.
I simulated the second, more complicated case with interfoam, turbulence off (laminar). I used the finest grid mentioned in the publication, around 50 thousand elements. Only with a maxCo as low as 0.01 I got results which very close to the ones in the reference solutions. The shape of the deformed bubble was most similar to the results of FReeLife, a free surface library for a FEM code. I give both results as appendix: Left is the paraFoam output, right is the repainted version of Fig. 19/Hysing.
The center of mass for my solution at the end of the simulation (t=3s) was 1.14. The others got 1.138 - 1.125 - 1.138.
sadra2003 likes this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 28, 2018, 03:04
cyw
Yuanwei Cao
Hey there,
Originally Posted by piu58 View Post
Dear Foamers,
Thank you for your kind reply. I have validated the case you mentioned in the paper of Hysing et alii. The result is good. But I want to make a step further. So I simulated the 3D cases with interFoam. Gerris uses the Geometric VOF method with height function, which is more accurate while interFoam uses algebraic VoF method. I wonder if there is something wrong with my setting or with the accuracy of the solver. I hope it is my wrong setting that makes the result unaccurate. If so, please help me to correct it.
Old   March 8, 2022, 03:06
Smile bubble rise velocity
sadra mahmoudi
sadra2003 is on a distinguished road
Dear Foamers,
Hello Uwe Pilz,
Thank you for the info you provided here.
I would be appreciative if you let me know your opinion. (I have attached my case)
I am also working on the terminal velocity of bubbles. Using the paraView, I measure the center of a bubble location in two successive time step, then by deviding the displacement of the center of bubble to the time difference, I wannt to calculate the velocity. The problem is, the value that I gain is 50 % lower than the reported values in the literature. I am using a 2D mesh in openFoam 8 using interFoam.
The contents of my 0 folder are:
U file:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
bottom
type noSlip;
outlet
type noSlip;
walls
type slip;
defaultFaces
type empty;
p_rgh file:
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 0;
boundaryField
bottom
type zeroGradient;
outlet
type zeroGradient;
walls
type zeroGradient;
defaultFaces
type empty;
alpha file:
dimensions [0 0 0 0 0 0 0];
boundaryField
bottom
type zeroGradient;
outlet
type zeroGradient;
walls
type zeroGradient;
defaultFaces
type empty;
transportProperties file:
phases (air water);
air
transportModel Newtonian;
nu nu [ 0 2 -1 0 0 0 0 ] 1.5E-5;
rho rho [ 1 -3 0 0 0 0 0 ] 1.18;
water
nu nu [ 0 2 -1 0 0 0 0 ] 7.22E-7;
rho rho [ 1 -3 0 0 0 0 0 ] 995.7;
Thanks a lot.
sadra2003 is offline   Reply With Quote
Old   March 10, 2022, 06:18
piu58's Avatar
Uwe Pilz
I have added my case. I hope you have success with it.
If you have any questions please write me a note.
littleJazz likes this.
Uwe Pilz
Old   March 10, 2022, 06:58
Smile 4mm bubble velocity
sadra mahmoudi
Thank you Uwe Pilz.
Could you get accurate results for different bubble size with this case?
The results that I get is really fluctuating for a 4mm bubble movement in water at realistic conditions (g=9.8). I would like to know whether you also get the same results or the bubble terminal velocity in your case approaches a distinct value?
atached, please see my result. The average of my result is correct for the terminal velocity of a 4mm bubble but the instantaneious velocity fluctuates alot.
Old   March 11, 2022, 02:09
piu58's Avatar
Uwe Pilz
From my notes (2017):
The most important change I made was reducing maxCo. A a mesure I used the coordinate of the center of gravity y_c. From Hysing it hast to be 1.14 for t=3.
maxCo y_c    time for calculation/h
1     0.86
0.5   0.88   0.24
0.1   1.03   0.8
0.03  1.10   2.7
0.01  1.12   7.3
0.003 1.123 22.3
0.001 1.124 62
Eventual, I stayed with maxCo=0.01. The simulation run for more than 7 hours with my computer of 2017.
I changed schemes too, but that gave not an important effect.
Uwe Pilz
Old   March 31, 2022, 07:17
Feng
fengyi is on a distinguished road
Originally Posted by sadra2003 View Post
Thank you Uwe Pilz.
Hi Sadra:
1.it is not surprised that bubbles' rising velocity simulated by 2D is smaller than that by 3D or by experiment. You can read this paper which compare rising velocity of 2D and 3D simulation using another free CFD software basilisk(Tripathi M K, Sahu K C. Motion of an air bubble under the action of thermocapillary and buoyancy forces[J]. Computers & Fluids, 2018, 177: 58-68.).I think 2D simulation means infomation is lost in one dimension compared with 3D simulation, so the result is incorrect more or less. My suggestion is that using full 3D simulation for bubble rising problem and for some bubble experencing recttilinear path you may use the 2.5D simulation(axisymmetry wedge grid).
2.the result concerning 4mm bubble's instantaneous velocity in water may be right. I think you must know that if bubbles are so big, they will experience an instability path, which may result in instablity. Of course, your result show a stong amplitude, but I read a paper presenting the similar velocity amplitude for big bubble in water(Antepara O, Balcázar N, Rigola J, et al. Numerical study of rising bubbles with path instability using conservative level-set and adaptive mesh refinement[J]. Computers & Fluids, 2019, 187: 83-97.)
Hope it is useful for you.
Best regards,
Feng
fengyi is offline   Reply With Quote
Old   April 5, 2022, 05:47
sadra mahmoudi
Hi Feng,
I really appreciate your help and your response.
Its true that in a 2D simulation, the results is not like a 3D simulation. I actually expected some differenceas between the results. My main problem / question is fluctuation of the terminal velocity of bubbles. Its amplitude is high for all bubbles that I have simulated yet (2D) while the terminal velocity that the other people plotted in this forum does not behave like mine. Almost all of them have a mild amplitude and the velocity does not flictuate a lot. In some cases, they considered g=0.98 to have a milder fluctuation in velocity but I am not sure whether in a realistic case (g=10), the velocity fluctuates a lot or not.
Old   April 5, 2022, 05:48
Thumbs up fluctuation of velocity
  #13
sadra mahmoudi
Originally Posted by fengyi View Post
Hi Sadra:
Best regards,
Feng
Hi Feng,
Attached, you can see the velocity and the trajectory of a 10 mm bubble (diameter) in water. Do you think that this fluctuiation is normal?
Thanks again.
Old   April 5, 2022, 07:31
Default velocity fluctuation
  #14
sadra mahmoudi
1     0.86
0.5   0.88   0.24
0.1   1.03   0.8
0.03  1.10   2.7
0.01  1.12   7.3
0.003 1.123 22.3
0.001 1.124 62
Hi Uwe,
Thank you so much for your help. I reduced the CO number and my results get better but still they fluctuate. Is this fluctuation normal for g=10 and diameter of 10mm?
Old   April 5, 2022, 07:48
Feng
Hi Feng,
Thanks again.
Hi Sadra:
1. In fact, I am a beginner for OpenFOAM, too. I don't know why you use g=0.98m/s2 instead of g=9.81m/s2 in reality. According to my 3D simulation experience about bubbles rising in pure water in really gravity g=9.81m/s2, bubbles whose diameter are larger than 2mm may experience a oscillating path and result in a oscillating velocity.
2. I recommend you validate your simulation procedure by using some robust simulation or experiment results first. Of course, you'd better begin with the simplest one--rectilinear path. Just chose some situation as your initial condition(eg. 1mm bubble in pure water) and compare your results with the reference.
BTW, following is a starting case associated with a paper focusing on bubble rising problem using OpenFOAM-v2012 which may help you:https://wiki.openfoam.com/Bubble_ris...nning_the_case
Best regards,
Feng
Old   April 5, 2022, 07:57
Default velocity
  #16
sadra mahmoudi
Hi Sadra:
Best regards,
Feng
Hi Feng,
Thanks.
I did not use g=0.98. I used g=9.81 to be realistic. I have seen some literature that the other researchers used g=0.98.
I checked my results with the experiment and the final results are good. The problem is, in the experimental works, just one value is reported as the velocity in many of the papers and the velocity fluctuation over time is not reporrted by the researchers. So, if I make an average over my data for terminl velocity, it is almost correct, compared to the reported value by experimentalists. I would like to know the bubble velocity behavior vs time flow.
Best,
SM
Old   April 5, 2022, 08:07
Feng
Hi Feng,
Thanks.
Best,
SM
Hi Sadra:
Sorry for my misunderstanding. Yes, experimentalist usually report their average terminal velocity only. I'm sorry that I can not provide you more suggetion.
Best regards,
Feng
Old   April 5, 2022, 08:12
Default Fluctuation of bubble terminal velocity
  #18
sadra mahmoudi
Hi Sadra:
Best regards,
Feng
Hi Feng,
Thankd for your guidance. I would be apprecitive if you update me if you obtain new insight on this topic.
Warm regards,
SM
Getting a concentration field around a bubble in InterFoam azman OpenFOAM Running, Solving & CFD 3 June 7, 2022 04:21
Rising Bubble Test Case Using interFoam: Unrealistic Results?! farazarbabi OpenFOAM Running, Solving & CFD 21 May 7, 2021 08:45
rising bubble vof simulation in fluent vinita123 FLUENT 0 December 21, 2015 07:49
rising bubble vof simulation in fluent vinita123 Main CFD Forum 2 December 21, 2015 07:40
VOF single bubble rising velocity! Lincoln Main CFD Forum 3 April 10, 2012 10:04
