Nusselt Number calculation differs with limitedlinear and vanleer
Like Tree2Likes
  • 1 Post By piu58
  • 1 Post By piu58
Old   March 28, 2018, 02:46
Default Nusselt Number calculation differs with limitedlinear and vanleer
Manu Chakkingal
manuc is on a distinguished road
Hello All
I am calculating Nusselt #at the wall using multiregionfoam during runtime.
swak4foam is used for calculating the wall averaged Nusselt #.
Issue
When I use vanleer scheme for divSchemes my results are close to experimental results.
When I use limitedlinear scheme for divSchemes my results are off by 20% w.r.t experimental results. [ tried with factors 0.33, 0.5 and 1]
I would like to have a pseudo-DNS kind simulation, because of which I prefer to use limitedlinear.
[Though both the schemes are 2nd order accurate I believe limitedlinear is more close to CDS]
Does the current results indicate that I need fine mesh for limitedlinear.
Nu=L*snGrad(T)/dT , where L=characterisitc length, T=Temperatute, dT =delta Temeprature (between hot and cold walls)
Any suggestions would be of great help.
Thanks
Regards
Manu
manuc is offline   Reply With Quote
Old   March 28, 2018, 02:53
Default Nusselt number calc
Ramana
svramana is on a distinguished road
Originally Posted by manuc View Post
Hello All
Issue
Thanks
i am dealing with a problem where i need to calculate local Nusselt number variation along the surface of the cube.
.can i have access to your code
Regards,
Ramana
svramana is offline   Reply With Quote
Old   March 28, 2018, 02:54
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
I always use Gauss limited linear with factor 1 (which is not limited, in effect). With these schemes I calculated a few cases for which theoretical solutions exist. I was always satisfied with the results. My cases included heat transfer and Nusselt numbers.
May it be, that your material constants are slightly off and you "compensated" this by the scheme?
manuc likes this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 28, 2018, 03:00
Manu Chakkingal
Dear Pilz
Thanks for your reply. Could you please let me know what you mean by
Thanks
Regards
Manu
Old   March 28, 2018, 04:18
piu58's Avatar
Uwe Pilz
In your simulation yu have to use the thermal conductivity, heat capacity, Prandl number and perhaps some more. Most of these are temperature dependent, and in many cases not known to the very last decimale. It may be that the real values differs from the ones you set in the simulation.
manuc likes this.
Uwe Pilz
Old   March 28, 2018, 04:56
Manu Chakkingal
Oh..I am using the values from experiments that we did and they are giving good results with other schemes. So I doubt that could be an issue. Thank you for the msg. I would certainly look if I messed up something.
Regards
Manu
