windaround Tower openFoam
Like Tree2Likes
  • 1 Post By RobertHB
Old   April 12, 2018, 06:30
Smile windaround Tower openFoam
Ximena
Ximena is on a distinguished road
I'm really new in openFoam. I'm trying to simulate wind-flow around a 39-story building , I could run the windAroundBuildigs tutorial and to starting I just tried replacing the buildings.obj.gz file (inside ...buildings/constant/triSurface folder) for mytower.stl.zip and also for mytower.obj.zip.. But it didn't work. I also opened the buildings.obj file and y i noticed that mytower is 100 time bigger than the buildings from the tutorial. Could someone explain to me how can i change the BC to run the same tutorial with mytower model (real-scale)?
I would really appreciate your help.
Ximena
Ximena is offline   Reply With Quote
Old   April 12, 2018, 08:12
Robert
RobertHB is on a distinguished road
Hello ximena,
i guess you have several options here. 1) rescale your tower.stl with e.g. Blender or 2) resize the blockMesh of windAroundBuildings so that your tower.stl fits inside.
Anyhow, you should place your tower.stl inside constant/triSurface not the zipped version. And remember that you have to remesh the case (run blockMesh as well as snappyHexMesh) so that you structure appears in the mesh.
Ximena likes this.
RobertHB is offline   Reply With Quote
Old   April 13, 2018, 08:32
Ximena
Thanks for your reply, I tried doing that
- Reduce tower.stl (on Fusion 360) because was faster for me than resize blockMesh .
- Open both of them on Paraview (and Fusion) to check if the origin and sizes matched, and those matched.
-Extra: Edit snappyHexMesh and surfaceFeatureExtract textEdit files (changing buildings.obj to buildings.stl).
-Run
It works thanks a lot!!
Now, could you help me again. I want to reproduce it but to real-scale , i guess that i have to edit blocMeshDict, is this the only file should I edit? and what parameter do I change?
Old   April 16, 2018, 03:05
Robert
-Run
Option 1: Change your blockMesh dictionary and your .stl to reflect the scale you want. Most likely the easiest way.
Option 2: Make use of the dynamic similarity of the flow. That would mean keeping the Reynolds number constant between your actual and mesh size, while changing the viscosity. Here is a link to a paper by Bolster et al. (2011), which is a pretty good and understandable introdutction to the topic.
Ximena likes this.
cfd, openfoam, windaroundobuildings
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
OpenFOAM Foundation releases OpenFOAMŪ 3.0.0 CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 1 November 7, 2015 15:16
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 13:36
OpenFOAM Foundation Releases OpenFOAM v2.3.0 opencfd OpenFOAM Announcements from OpenFOAM Foundation 3 December 23, 2014 03:43
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 07:18
