Difficulties with setup of interFOAM VOF - Boundary Conditions?
Like Tree1Likes
  • 1 Post By Taataa
Old   April 13, 2018, 07:05
Default Difficulties with setup of interFOAM VOF - Boundary Conditions?
Dave
DaveR is on a distinguished road
I've been trying to simulate water & air flow past a yacht in a domain with an initialed volume of fluid, as illustrated below.
However, when I simulate this I get peculiar behavior at the inlet patch, wherein the water seems to climb the boundaries of the domain in the opposite direction of fluid flow, as shown below.
I've taken the yacht out of the simulation in an effort to speed up simulation times while I rectify this. I've tried altering patch types, positions (i.e. the air inlet/outlet being the top surface opposed to the side surfaces), differing flow velocities, and initializing the volume of fluid with a uniform velocity matching the inlet boundary condition. All of my simulation iterations seem to demonstrate the same behavior.
Is anyone able to offer any suggestions on how to correct this?
I've attached my case below for your reference.
https://drive.google.com/open?id=1hF...KbXubSQNJMM3a_
Thanks and best regards
DaveR is offline   Reply With Quote
Old   April 13, 2018, 11:19
Taher Chegini
Taataa is on a distinguished road
BCs are wrong. I would suggest you to take a look at the wave tutorial of OF, here.
Moreover, there is no need breakup all the domain like the way you did. If you don't want to use the wave BC you might want to divide the inlet only not outlet and sides. Also, because you're using interFoam you should use fixedFluxPressure instead of zeroGradient for pressure and pressureInletOutLetVelocity for velocity for the boundaries where you use totalPressure for pressure.
The general idea is that in this kind of problems you should specify velocity at the inlet (fixedValue for velocity and fixedFluxPressure for pressure) and pressure at the outlet (totalPressure for pressure and pressureInletOutLetVelocity for velocity).
Taataa is offline   Reply With Quote
Old   May 6, 2018, 09:12
Smile fixedFluxPressure
Srikar Reddy Palla
SRKR is on a distinguished road
Can you please explain me about 'fixedFluxPressure' ?, why do i need to apply that instead of zeroGradient in interFoam? Please enlight me on this.
SRKR is offline   Reply With Quote
Old   May 6, 2018, 09:30
Taher Chegini
You can find good explanations here.
SRKR likes this.
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 01:44
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 21:16
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
