problem with AMI + patchMeanVelocityForce
Old   June 20, 2018, 09:53
Default problem with AMI + patchMeanVelocityForce
GD
gorgon is on a distinguished road
Send a message via Skype™ to gorgon
Hello guys,
I'm running a case with periodic in/out with cyclicAMIs at inflow and outflow with identical inflow / outflow surfaces (and obviously the same area)
The mass flow rate is specified through a patchMeanVelocityForce fvOption and the MRF is active as well
The problem is that I get the usual problem:
--> FOAM FATAL ERROR:
Continuity error cannot be removed by adjusting the outflow.
Total flux : 5.6995106
Specified mass inflow : 0.0001926572
Specified mass outflow : 0.000192735712
Adjustable mass outflow : 0
any ideas?
thanks in advance
GD
gorgon is offline   Reply With Quote
Fluent Parallelization Problem After AC Power Dropped pawl Hardware 5 November 13, 2016 06:08
Problem using AMI 3D calaba OpenFOAM Running, Solving & CFD 0 July 27, 2016 06:30
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
