MovingWallVelocity Boundary Condition
Like Tree4Likes
  • 2 Post By ralph
  • 2 Post By lr103476
Old   June 8, 2007, 07:11
Default Hi, I want to simulate a pitc
Ralph
ralph is on a distinguished road
I want to simulate a pitching airfoil.
My question is about the boundary conditions.
1) As there is a non constant velocity of the wall along the airfoil, I canīt use the fixedValue boundary condition.
Is the following boundary condition applicable for U?
AIRFOIL
type movingWallVelocity;
value uniform (0 0 0);
Does it mean, that there is a zero relative velocity forced at the wall?
2) Can I leave the boundary conditions for all other variables as they are in the case with non-moving walls?
Ralph
ralph is offline   Reply With Quote
Old   June 12, 2007, 05:47
Ralph
AIRFOIL
Ralph
Old   June 12, 2007, 06:05
Default Hi Ralph, 1) You need the
Frank Bos
lr103476 is on a distinguished road
Hi Ralph,
1) You need the movingWallVelocity boundary condition for U on the moving wall. This boundary condition corrects the flux due to mesh motion in such a way that the total flux phi through the moving wall is zero. The way it should be the case, you can check phi in the time dirs.
2) When you are using icoDyMFoam, you only have motionU, U and p. Leave p and the rest of U like in case of nonmoving wall. In motionU define the motion of the wall by applying the oscillationFixedValue BC, or take fixedValue (0 0 0) when the motion of the wall is defined by using a dynamicFvMesh lib. To be safe, take fixedValue (0 0 0) on all outer boundaries, except the symmetry and empty patches. If you dont take fixedValue, but zeroGradient on the inlet, it might move with the flow....Also nice, but you dont want that :-)
Goodluck,
Frank
YUGU and charlliemarshalll like this.
Frank Bos
lr103476 is offline   Reply With Quote
Old   June 12, 2007, 06:47
Default Thanks a lot Frank. Ralph
Ralph
Thanks a lot Frank.
Ralph
Old   January 10, 2012, 10:57
Default flapping simulation
Malu
Malu006 is on a distinguished road
hey everyone, i was also stuck at simulating a pitching airfoil simulation, finally i was able to do so uisng sixDoFRigidBodyDisplacement. now i have to add a heaving motion along with the pitching motion. i first tried to do so it by changing the constraints (fixed axis and fixed line), but this did not work. does anyone have an idea about how to go about this?
Thanks
Malu
Malu006 is offline   Reply With Quote
Old   January 10, 2012, 11:36
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Thanks
Malu
It will work. I've been using it for a long time, just be careful about the directions settings. Reexamine and Retry.
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   January 23, 2013, 13:33
Sasan Ghomi
sasanghomi is on a distinguished road
Hi every body
I did'nt understand what is value(0 0 0) in movingWallVelocity boundry condition????/
Can any one explain???
sasanghomi is offline   Reply With Quote
Old   June 18, 2013, 07:15
Artur's Avatar
Artur
Artur will become famous soon enough
Originally Posted by sasanghomi View Post
Hi every body
I think it's equivalent to the no-slip condition for a standard wall-type patch except here it refers to a moving one...
Artur is offline   Reply With Quote
Old   October 20, 2017, 06:17
saurabh shubham
saurabhshubham is on a distinguished road
hi everyone.
I am using the same code for the case of heaving airfoil as I did use for transverse oscillating cylinder.
but when I am checking the velocity at the tip of the airfoil at t=0, then the value is not zero, as in case of oscillating cylinder case.
even after running it for few seconds the vorticity contours starts originating from the front of the airfoil.
saurabhshubham is offline   Reply With Quote
Old   July 3, 2018, 02:49
Chayanit Nigaltia
CHAYANIT is on a distinguished road
Thanks
Malu
I am struck in piching airfoil case. Can you help me in this case??
CHAYANIT is offline   Reply With Quote
Patch end points mesh motion and movingWallVelocity pbo OpenFOAM Running, Solving & CFD 14 October 4, 2023 11:20
Boundary condition for UDS Tomik FLUENT 1 December 11, 2006 08:50
Boundary condition of the third kind or Danckwertz boundary condition plage OpenFOAM Running, Solving & CFD 4 October 3, 2006 12:21
Slip Boundary Condition for Moving Boundary Shukla Main CFD Forum 3 November 11, 2005 15:02
Boundary Condition Mohammad Bagher Ayani Main CFD Forum 1 January 11, 2002 17:29
