Case exiting after time = 1. Set-up error?
Old   January 22, 2019, 09:20
Default Case exiting after time = 1. Set-up error?
Kieran is on a distinguished road
Hi there,
I'm trying to simulate a case for a tidal turbine. Ive meshed a single blade (of 3) in Pointwise, in a 1/3rd cylinder domain, with cyclic boundary coniditions, using the T-Rex feature to generate a hybrid mesh.
Using checkMesh returns that the mesh is okay (I've attached the log), but when I try to run the case, only a single iteration is started before exiting.
I'm quite new to OpenFOAM, and I can't work out why it's not proceeding after a single iteration. No error message is produced as far as I can tell, it just seems to end abruptly (log also attached).
Im using the SRFSimpleFOAM solver. My end time is in ControlDict is currently set to 500 with deltat of 1, which is low but I wanted to check the solver would properly initialise first. I've tried browsing the forums and google, but I don't know what my problem is so it's hard to find similar cases.
Thanks in advance. If any further detail is needed please let me know. I've also attached the fvsolution and fvscheme files.
Kieran
Kieran is offline   Reply With Quote
Old   January 23, 2019, 03:08
sufjanst is on a distinguished road
You said that a deltat of 1s is low. That sounds like you want to run the simulation in transient. 1s of deltat is way to large for a transient simulation. Your values in your controlDict look more like they should be used in a steady-state simulation.
Does your simulation finish after 1 itertion or does it crash?
Do you get an error message?
sufjanst is offline   Reply With Quote
Old   January 23, 2019, 04:10
Thanks for replying sufjanst, I was thinking my end-time of 500 was a bit low, I would be expecting to run for thousands of timesteps, but this is just for testing. I am looking at steady-state simulations.
It finished as far as I can tell, there was no error message or crash log. I found my issue though I think. I changed my solver in fvsolution from GAMG to PCG and also realised my geometry scale was wrong, so adjusted using transformPoints. It now is able to run past time = 1.
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
