Pressure Driven Flow in Tube
Old   July 24, 2018, 13:05
Question Pressure Driven Flow in Tube
George
last_jedi is on a distinguished road
Hello guys, i am trying to solve a case with icoFoam in a simple tube geometry, where laminar flow is driven by pressure.
More specific pressure is implemented in a sinusoidal form. I have been facing a problem with setting the BCs correctly.
Especially for outlet in pressure file, when i use zeroGradient case runs but results are not good. When i change this BC to fixedValue 0, then after some iterations CFL goes crazy. Pls any help would be great. My BC files can be seen below:
|  \\    /   O peration     | Version:  dev                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
      type            uniformFixedValue;
      uniformValue    sine;
      amplitude       6.85;
      frequency       0.25;
      scale           1;
      level           0;
      refValue        uniform 0;
    outlet
        type            fixedValue;
        value           uniform 0;
    wall
        type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (0 0 0);
    outlet
        type            fixedValue;
    wall
        type            fixedValue;
last_jedi is offline   Reply With Quote
Old   July 25, 2018, 04:59
anonymous
simrego is on a distinguished road
Hi!
You should use zeroGradient for velocity on the inlet and outlet if you define the pressure there.
simrego is offline   Reply With Quote
Old   July 25, 2018, 10:19
George
Originally Posted by simrego View Post
Hi!
Hi Simrego, i have tried also with zeroGradient for velocity inlet and outlet and CFL still goes crazy after a while..
Old   July 25, 2018, 15:37
anonymous
You should use zeroGradient, but at least not fixedValue (0 0 0).
If it's possible to post your case or at least a simplified (if your geometry is not public) one, it's easier to help you.
bcs, icofoam, openfaom, pressure driven flow
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 13:04
Discrepancy in Pressure Driven Flow Behaviour in 211 vs 221 cdm OpenFOAM Running, Solving & CFD 5 December 17, 2013 07:48
velocity and pressure driven flow in openfoam jr33 OpenFOAM Running, Solving & CFD 1 August 7, 2013 11:00
pressure driven flow by pressure correction method justentered Main CFD Forum 0 December 29, 2003 23:52
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
