August 24, 2018, 01:55 |
Heat source problem chtMultiregionSimpleFoam
#1 | |
Hello Everyone,
I am using OF50 for 2D steady state conjugate heat transfer problem (using chtMultiregionSimpleFoam) with heat source. I have 84 disconnected solid region (blue part in image) and fluid passing across solid regions (green part). I have used following fvOptions file for heat source Quote:
The heat source is correct for my setup because same heat source has been used in Ansys and giving physical results. In my case (OpenFOAM), I used 298K as initial temperature for both solid and fluid regions. Once I start simulation, the temperature keep on increasing for both sold and fluid region (I checked temperature rise up to 500K in 50000 iteration). I am unable to figure out my mistake. Could anyone please tell me the right direction to look for my mistake. I have attached my log file with it (due to size constraints I could not attach my complete log file). Moreover, I have used same simulation setup for transient case with initial temperature of solid 333K and it was fine with results comparable with ansys as well as experiments. PS: Unfortunately, I cannot share my entire case here Regards |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
[swak4Foam] swak4Foam-groovyBC build problem | zxj160 | OpenFOAM Community Contributions | 18 | July 30, 2013 13:14 |
