Different Meshes for Different Physics
Old   August 26, 2018, 16:59
Default Different Meshes for Different Physics
physicsunited's Avatar
Pi-Man
physicsunited is on a distinguished road
Dear fellow cfd-online members,
I am using a modified icoFoam setup, that couples transient passive scalar transport to the momentum equations.
My issue is that my momentum equations don't require a fine mesh, while my scalar transport problem requires a relatively very fine mesh (due to high Peclet numbers). This further constrains my time step choice (due to the Courant number and viscous stability constraints) and adds a significant number of time steps to my problem. These time steps do not add significant physical information to my problem, but are rather there due to numerical stability requirements. Basically in one of the equations I have to use very fine mesh while the other one works OK with a coarser mesh.
I was wondering whether it would be possible to solve my coupled system on different meshes (one for each set of equations), and project the velocity results from the coarse mesh to the finer mesh to be used in solving my scalar transport equation.
Is there anyway that I can assign different meshes for each of these equations and thus save computational time?
Best,
Pi-Man
physicsunited is offline   Reply With Quote
Old   August 27, 2018, 00:40
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
You may always use a script which runs both simulations, one after the other. You need a tiny program in the programming language of your choice, which reads the velocity results of the coarse mesh and transfers it (with interpolation) to the finer one.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   August 27, 2018, 01:43
Peter Baskovich
pete20r2 is on a distinguished road
I'd be curious to see how you go, I suspect you will spend more time interpolating and IO operations than just solving on the fine mesh. Unless you do it inside the one solver with two meshes and keep the fields in memory while you solve I don't think you'll see the benefit.
pete20r2 is offline   Reply With Quote
Old   August 27, 2018, 04:42
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
It can be done, see this post of mine, which contains a screenshot.
I took inspiration from the multi-region solvers, and the mapFields utility.
I have no idea, when the additional effort (the second mesh, the mapping of fields each time step) is worth it.
GerhardHolzinger is offline   Reply With Quote
coupled equations, multiphysics, multiple meshes
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Different Physics Contnuum for Same Region itsanisant STAR-CCM+ 0 October 10, 2014 00:30
Hex and Tet meshes - simplefoam comparison danvica OpenFOAM Running, Solving & CFD 10 January 4, 2013 01:18
Multiple Physics Continua boathead STAR-CCM+ 6 December 4, 2011 12:33
physics phD to CFD? jck87 Main CFD Forum 13 October 9, 2010 16:15
