Forcing update on boundary fields after each iteration
Old   September 10, 2018, 19:43
Default Forcing update on boundary fields after each iteration
Pavan
pvpnrao is on a distinguished road
I am using pimplefoam in Openfoam 5.x.
The boundary condition seems to update only once per timestep.
I need this updating to take place after each pimple loop as well as at the end of the time-step.
Can some one suggest how to edit pimpleFoam to achieve this?
pvpnrao is offline   Reply With Quote
Old   September 11, 2018, 10:18
Pavan
Any clues?
Old   September 11, 2018, 10:42
anonymous
simrego is on a distinguished road
Hi!
As i know it is updated in every equation solving. Check the code or just simply write a pretty dummy coded BC, for example:
https://cpp.openfoam.org/v6/classFoa...d.html#details
just set operator==(0);
and use as a pressure BC at outlet.
and also write out that the BC is evaluated before operator==;
ie:
Info<< "Here is my BC again..." << endl;
If you see this message, your BC is evaluated. You will see this message a lot in the logs!
simrego is offline   Reply With Quote
Old   September 11, 2018, 11:27
Pavan
simrego
Thank you very much for the quick response.
I am printing the area averaged pressure at inlet boundary after each pimple loop. The inlet pressure fluctualtes in the first few pimple loops then settles for a fixed negative value for rest of the PIMPLE iterations.
I am intializing the case with converveged solution from a steady state run . The areaAverageInletPressure at the begining of the first time step shows the initial pressure. But the solution does not reach the same pressure at the end of the time step. At least in the first timestep I expect the inlet pressure to be equal to the initialized value.
My cluster system is under maintenence today, i will post the iteration log ASAP.
Meanwhile, any comments or suggestions will be helpful.
Old   September 11, 2018, 11:53
Santiago Lopez Castano
Santiago is on a distinguished road
Originally Posted by pvpnrao View Post
simrego
There is a class member in geometrciFields called correctBoundaryConditions()
So, if you write
U.correctBoundaryConditions();
Youll get what you intend.
Santiago is offline   Reply With Quote
Old   September 11, 2018, 12:10
Pavan
Santiago
I tried this option, please see the code below. I dont know whether I placed the code within the proper loop or not. Nonetheless, it did not work. Please suggest if needs to be placed somewhere else:
// --- Pressure-velocity PIMPLE corrector loop
while (pimple.loop())
#include "UEqn.H"
// --- Pressure corrector loop
while (pimple.correct())
#include "pEqn.H"
if (pimple.turbCorr())
laminarTransport.correct();
turbulence->correct();
Furthermore this systax is present in the list one of pEqn.H. So, I guess it is already being executed, but I could not see any difference.
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 05:53
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 04:39
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 11:19
an odd(at least for me!) reconstructPar error on a field immortality OpenFOAM Running, Solving & CFD 3 June 3, 2013 22:36
