September 30, 2018, 15:20 |
Chtmultiregionfoam Error
Ümit Yelken
Rep Power: 8 |
Hi guys,
Im using openfoam 2.1.1 and mixed foam of chtmultiregionfoam and ddtfoam(ettner). I have cylindrical 3 region innerWall,outerWall and fuelMixture. When i give zeroGradient for T between walls and fuelMixture it works without error. But when i give this BC below i take error. Or when i give fixedGradient it works! type compressible::turbulentTemperatureCoupledBaffleMix ed; value uniform 293; neighbourFieldName T; K basicThermo; KName none; The error is: Code:
[14] #0 Foam::error::printStack(Foam::Ostream&) in "/home/workstation/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [14] #1 Foam::sigFpe::sigHandler(int) in "/home/workstation/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [14] #2 [14] at sigaction.c:0 [14] #3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) in "/home/workstation/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [14] #4 void Foam::sqrt<Foam::fvPatchField>(Foam::FieldField<Foam::fvPatchField, double>&, Foam::FieldField<Foam::fvPatchField, double> const&) at ~/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/scalarFieldField.C:107 [14] #5 void Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ~/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/GeometricScalarField.C:450 [14] #6 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ~/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/GeometricScalarField.C:450 [14] #7 [14] at ~/cht_ddt_solver/chtDdtFoam/fluid/XiEqn.H:73 [14] #8 __libc_start_main in "/lib64/libc.so.6" [14] #9 [14] in "/home/workstation/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/chtDdtFoam" [ws:17157] *** Process received signal *** [ws:17157] Signal: Floating point exception (8) [ws:17157] Signal code: (-6) [ws:17157] Failing at address: 0x3e800004305 [ws:17157] [ 0] /lib64/libc.so.6() [0x3a93c359b0] [ws:17157] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x3a93c35935] [ws:17157] [ 2] /lib64/libc.so.6() [0x3a93c359b0] [ws:17157] [ 3] /home/workstation/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam4sqrtERNS_5FieldIdEERKNS_5UListIdEE+0x30) [0x7fa8daed16d0] [ws:17157] [ 4] chtDdtFoam(_ZN4Foam4sqrtINS_12fvPatchFieldEEEvRNS_10FieldFieldIT_dEERKS4_+0x57) [0x4c108a] [ws:17157] [ 5] chtDdtFoam(_ZN4Foam4sqrtINS_12fvPatchFieldENS_7volMeshEEEvRNS_14GeometricFieldIdT_T0_EERKS6_+0x5e) [0x4b0a0e] [ws:17157] [ 6] chtDdtFoam(_ZN4Foam4sqrtINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKS8_+0xfd) [0x498673] [ws:17157] [ 7] chtDdtFoam() [0x47fba2] [ws:17157] [ 8] /lib64/libc.so.6(__libc_start_main+0xf5) [0x3a93c21735] [ws:17157] [ 9] chtDdtFoam() [0x43e079] [ws:17157] *** End of error message *** |
October 1, 2018, 01:46 |
Tobias Holzmann
Rep Power: 51 |
there should be a division by zero Code:
Keep foaming, Tobias Holzmann |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
