Impeller: temperature decreasing, should be increasing
Like Tree9Likes
Old   June 5, 2020, 16:13
Charlie Marshall
charlliemarshalll is on a distinguished road
Thanks a lot!
I see that I should have changed all the related p_rgh to 1e5, especially the surrounding fixedFluxPressure, not just the internalField and the outlet.
Cheers! Please let me know if you need any help in the future. Gonna test the more difficult scenarios.
Regards,
Charlie
charlliemarshalll is offline   Reply With Quote
Old   March 10, 2024, 19:15
Default OpenFOAM simulation of a compressor, rhoSimpleFOAM
  #22
Alex
brateboj is on a distinguished road
I am facing the same problem of above. I am running a CFD simulation in OpenFOAM (v10) of a compressor, working fluid perfect gas. The solver is rhoSimpleFOAM, MRF approach, omega = 1500 rad/s , the pressure and velocity fields are correctly simulated, while the Temperure does not increase as it should, it remains almost constant.
could you kindly give me a hand?
brateboj is offline   Reply With Quote
compressible, impeller, temperature bc
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 10:20
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 17:00
unexpected constant Temperature on a clip surface Sungki OpenFOAM Running, Solving & CFD 0 August 4, 2015 04:50
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
temperature increasing at zero heatflux wall dokeun FLUENT 0 May 26, 2011 00:33
