One phase, mixing of two different gases
Like Tree1Likes
  • 1 Post By tomf
Old   January 15, 2019, 09:40
Default One phase, mixing of two different gases
jcw
Christian Wolf
jcw is on a distinguished road
Hello!
After reading many threads in forum, I am still not sure, which OF solver to use.
I would like to simulate the mixing of 2 gases (air and CH4). Each gas component is entering a separate inlet. At the outlet I would like to evaluate the mixing quality. There is no phase change. Gases enter with different temperatures.
Which OF solver is appropriate? Is there a tutorial? I use OF4.1.
Thanks.
jcw is offline   Reply With Quote
Old   January 16, 2019, 01:20
jcw
Christian Wolf
No hints for my question?
Old   January 16, 2019, 03:38
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
You could have a look at reactingFoam and it's variants. If you turn off chemistry/combustion you will get just the mixing.
I would suggest looking at either of:
$FOAM_TUTORIALS/combustion/reactingFoam/laminar/counterFlowFlame2D
$FOAM_TUTORIALS/combustion/reactingFoam/laminar/counterFlowFlame2DLTS
depending on whether you want to look at time-accurate or steady-state simulations.
Regards,
Tom
pconen likes this.
tomf is offline   Reply With Quote
Old   January 18, 2019, 09:38
jcw
Christian Wolf
Hello!
Thanks for reply. I actually managed with simpleReactingParcelFoam. Lagrange off, non-reacting.
Regards
Old   July 25, 2023, 08:44
CFDUser29 is on a distinguished road
Originally Posted by jcw View Post
Hello!
Regards
Can you please share you constant and system directories please? I struggle to set a simulation with two gases.
CFDUser29 is offline   Reply With Quote
Old   September 25, 2023, 03:28
Default simpleReactingParcelFoam
jcw
Christian Wolf
Hello! It is a long time ago I used OF. My simulation is done with OF41. Maybe it will help.
| \      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \    /   O peration     | Version:  4.0                                   |
|   \  /    A nd           | Web:      www.OpenFOAM.org                      |
|    \/     M anipulation  |                                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss upwind;
    div(phid,p)     bounded Gauss upwind;
    div(phi,K)      bounded Gauss linear;
    div(phi,h)      bounded Gauss upwind;
    div(phi,k)      bounded Gauss upwind;
    div(phi,epsilon) bounded Gauss upwind;
    div(phi,omega) bounded Gauss upwind;
    div(phi,Yi_h)   Gauss upwind;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear uncorrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         uncorrected;
wallDist
    method meshWave;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver           GAMG;
        tolerance        0;
        relTol           0.05;
        smoother         DICGaussSeidel;
        maxIter          50;
    Phi
        $p;
    "(U|Yi|h|k|omega|epsilon)"
        solver          smoothSolver;
        smoother        GaussSeidel;
        tolerance       0;
        relTol          0.1;
        maxIter         20;
potentialFlow
    nNonOrthogonalCorrectors 5;
SIMPLE
    nCorrectors     2;
    nNonOrthogonalCorrectors 1;
    rhoMin          0.1;
    rhoMax          1.5;
relaxationFactors
    fields
        p               0.3;
        rho             1;
    equations
        U               0.7;
        h               0.7;
        ".*"            0.7;
mixing gases, one phase
Fluent Limitations tymcme FLUENT 6 August 1, 2022 08:50
rhoReactinBuoyantFoam - Buoyant Mixing of two gases rkc.cfd OpenFOAM Programming & Development 0 July 13, 2014 13:09
Please correction give me. 2 Phase flow mixing 2D realalife Fluent Multiphase 0 September 3, 2013 09:38
two Phase column simulation chemeng OpenFOAM 3 August 18, 2010 12:53
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
