Looking for a combustion solver
Old   February 4, 2019, 07:03
Default Looking for a combustion solver
Slim
sosos is on a distinguished road
Hello everyone, I am new with OpenFoam and I may lack some basis so I am sorry for that. I have a problem in choosing a combustion solver.
So, my task is to simulate a flame out of a burner. For this task I have three inlets, two are the same where only air is present and the last one consists of a premixed mixture of air and methane. By the way, the mixture inlet is located between the other two. You can think of it as vertical line divided into three parts where the middle part is the mixture inlet and where the upper and lower inlets only have air flow.Also, I am calling them inlets but in reality they are the outlet of the burner but for now I am only interested in simulating the flame and not what happens inside the tubes of the burner.
From what I read, XiFoam is the solver to use for premixed combustion, but I don't find the way to configure the inlets according to the task (2 inlets with only air and 1 inlet with a air-methane mixture.)
My question then is; Does XiFoam offer me the possibility to do it and I missed it or should I use another solver and in this case which one do you think I should turn to?
Thank you in advance for the help and also for the work you're doing and I hope my explanation was clear enough and if not please ask me for more clarification.
sosos is offline   Reply With Quote
Old   February 8, 2019, 06:48
sufjanst is on a distinguished road
Does every inlet act as an independent boundary? Normally you can set up every boundary individually. If it's not the case you have define every inlet as an own boundary in your meshing tool.
XiFoam should to the job. I personally prefer PaSR, which is pretty slow but gives very good results.
sufjanst is offline   Reply With Quote
Old   February 10, 2019, 08:24
Slim
Hello, thank you for your answer and I am sorry for the late reply.
I didn't understand your question quite well but I think that the inlets are independent. Well, maybe I wasn't clear in my explanation.
Also, I am not an OpenFoam expert so what is PaSR and how to use it because I can't find it in the combustion solvers.
As you can see in the picture, there is an air inlet and a gas inlet; well actually in my case in the gas tube there should be a premixed gas/air mixture. What I am interested in is the flame at the oultlet of the burner that means that for my simulation inlet refers to the outlet of the burner. For now I am not interested in what happens inside of the tubes.
So what I am looking for is a slover that can simulate premixed combustion and where I can specify for each inlet the components I have (only air, air+methane).
I hope this is more clear and I thank you for your replies.
PEMFC model with FLUENT brahimchoice FLUENT 22 April 19, 2020 15:44
Combustion problems: solver divergence occurs when turning on high temperature patch nishant FLUENT 2 February 8, 2015 05:20
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
premixed combustion - parallel solver error Craig FLUENT 0 October 14, 2008 15:07
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
