velocity profiles in sonicLiquidFoam
Old   September 13, 2020, 16:56
Default velocity profiles in sonicLiquidFoam
Didu is on a distinguished road
Dear foamers,
I'm trying to simulate a laminar flow (water) in a cylindrical shape using sonicLiquidFoam, the main problem is that the velocity profile is very different from what Hagen-Poiseuille expected. How can I correct this?
Comparing the results with rhoPimpleFoam, where the velocity profiles are correct, what is the main difference in the solver, and why this is happening?
Thanks in advance!!
Didu is offline   Reply With Quote
Old   September 14, 2020, 05:53
Krapf is on a distinguished road
Hi Didu
sonicLiquidFoam is a "[t]ransient solver for trans-sonic/supersonic, laminar flow of a compressible liquid" (source: OpenFOAM v6 User Guide: 3.5 Standard solvers).
Is your flow trans-sonic/supersonic?
Note: In the Foundation version sonicFoam, sonicDyMFoam, sonicLiquidFoam were merged into rhoPimpleFoam [ commit 3341f9 ].
Kind regards
Krapf
Krapf is offline   Reply With Quote
Old   September 14, 2020, 06:21
Hi Krapf,
Thank you for your response.
The flow that I'm dealing is not trans-sonic or supersonic.
It is a flow in a pipe with very low velocities, the Reynolds numbers range from 1 to 400 (laminar).
The main issue is that sonicLiquidFoam uses the barotropic relationship (I believe that it the only one), considering the bulk modulus (K) which is ideal to setup the pressure wave celerity, in my case (pipes).
Kind regards,
Didu
Old   September 14, 2020, 06:44
Maybe it's possible to use the barotropic relationship in rhoPimpleFoam (Foundation version 7 or 8) without setting "transonic yes;" in the PIMPLE sub-dictionary of fvSolution?
Old   October 9, 2020, 09:02
Thanks for your answer, I'm sure this is the solution, did anyone try to add the barotropic relationship to the rhoPimpleFoam solver?
laminar, sonicliquidfoam, velocity profiles
Matching the velocity profiles of two faces Shoh Fluent UDF and Scheme Programming 7 August 4, 2020 00:58
kindly help me .. i have and error at line number 147.. m zubair Fluent UDF and Scheme Programming 0 February 10, 2019 11:25
[OpenFOAM] How to Display multiple Velocity Profiles? ocin199 ParaView 2 May 17, 2017 03:47
User Defined Profiles, Swirl, Velocity Inlet saurus FLUENT 0 January 26, 2011 15:35
Velocity Profiles Sal FLUENT 3 August 2, 2007 09:06
