running iocFoam in parrallel
Old   October 3, 2019, 09:07
Default running iocFoam in parallel
anonymous
tenichols19 is on a distinguished road
I was able to run "icoFoam" in the terminal and the simulation ran fine. To speed up the process fro future simulations I will be running in parallel so I figured I would try it on this setup
When
decomposePar
it executed correctly but when trying to run icoFoam in parallel
mpirun -np 8 icoFoam -parallel | tee log
I get this
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
Build  : 7-6ef561967074
Exec   : icoFoam -parallel
Date   : Oct 03 2019
Time   : 08:41:49
Host   : "taylor-Precision-T1700"
PID    : 4645
I/O    : uncollated
Case   : /home/taylor/OpenFOAM/taylor-7/run/ten
nProcs : 8
Slaves :
7
"taylor-Precision-T1700.4646"
"taylor-Precision-T1700.4647"
"taylor-Precision-T1700.4648"
"taylor-Precision-T1700.4649"
"taylor-Precision-T1700.4650"
"taylor-Precision-T1700.4651"
"taylor-Precision-T1700.4652"
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Starting time loop
[0]
[0]
[0] --> FOAM FATAL ERROR:
[0] Unknown function type surfaceRegion
Valid functions are :
52
CourantNo
Lambda2
MachNo
PecletNo
Q
XiReactionRate
add
age
blendingFactor
components
ddt
div
enstrophy
fieldAverage
fieldCoordinateSystemTransform
fieldMinMax
fieldValueDelta
flowType
grad
histogram
interfaceHeight
log
mag
magSqr
nearWallFields
patchProbes
pressure
probes
processorField
psiReactionThermoMoleFractions
randomise
readFields
regionSizeDistribution
rhoReactionThermoMoleFractions
scale
sets
streamFunction
streamLine
subtract
surfaceFieldValue
surfaceInterpolate
surfaces
turbulenceFields
turbulenceIntensity
volFieldValue
vorticity
wallHeatFlux
wallHeatTransferCoeff
wallShearStress
writeCellCentres
writeCellVolumes
yPlus
[0]
[0]
[0]     From function static Foam::autoPtr<Foam::functionObject> Foam::functionObject::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&)
[0]     in file db/functionObjects/functionObject/functionObject.C at line 100.
[0]
FOAM parallel run exiting
[0]
[1]
[1]
[1] --> FOAM FATAL ERROR:
[1] Unknown function type surfaceRegion
52
CourantNo
Lambda2
MachNo
PecletNo
Q
XiReactionRate
add
age
blendingFactor
components
ddt
div
enstrophy
fieldAverage
fieldMinMax
fieldValueDelta
flowType
grad
histogram
interfaceHeight
log
mag
magSqr
nearWallFields
patchProbes
pressure
probes
processorField
randomise
readFields
scale
sets
streamFunction
streamLine
subtract
surfaceFieldValue
surfaceInterpolate
surfaces
turbulenceFields
turbulenceIntensity
volFieldValue
vorticity
wallHeatFlux
wallShearStress
writeCellCentres
writeCellVolumes
yPlus
[1]
[1]
[1]     From function static Foam::autoPtr<Foam::functionObject> Foam::functionObject::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&)
[1]     in file db/functionObjects/functionObject/functionObject.C at line 100.
[1]
[1]
[3] [4]
[4]
[4] --> FOAM FATAL ERROR:
[4] Unknown function type surfaceRegion
52
CourantNo
Lambda2
MachNo
PecletNo
Q
XiReactionRate
add
age
blendingFactor
components
ddt
div
enstrophy
fieldAverage
fieldMinMax
fieldValueDelta
flowType
grad
histogram
interfaceHeight
log
mag
magSqr
nearWallFields
patchProbes
pressure
probes
processorField
randomise
readFields
scale
sets
streamFunction
streamLine
subtract
surfaceFieldValue
surfaceInterpolate
surfaces
turbulenceFields
turbulenceIntensity
volFieldValue
vorticity
wallHeatFlux
wallShearStress
writeCellCentres
writeCellVolumes
yPlus
[4]
[4]
[4]     From function static Foam::autoPtr<Foam::functionObject> Foam::functionObject::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&)
[4]     in file db/functionObjects/functionObject/functionObject.C at line 100.
[4]
[4]
[5]
[5]
[5] --> FOAM FATAL ERROR:
[5] Unknown function type surfaceRegion
52
CourantNo
Lambda2
MachNo
PecletNo
Q
XiReactionRate
add
age
blendingFactor
components
ddt
div
enstrophy
fieldAverage
fieldMinMax
fieldValueDelta
flowType
grad
histogram
interfaceHeight
log
mag
magSqr
nearWallFields
patchProbes
pressure
probes
processorField
randomise
readFields
scale
sets
streamFunction
streamLine
subtract
surfaceFieldValue
surfaceInterpolate
surfaces
turbulenceFields
turbulenceIntensity
volFieldValue
vorticity
wallHeatFlux
wallShearStress
writeCellCentres
writeCellVolumes
yPlus
[5]
[5]
[5]     From function static Foam::autoPtr<Foam::functionObject> Foam::functionObject::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&)
[5]     in file db/functionObjects/functionObject/functionObject.C at line 100.
[5]
[5]
[6]
[6]
[6] --> FOAM FATAL ERROR:
[6] Unknown function type surfaceRegion
52
CourantNo
Lambda2
MachNo
PecletNo
Q
XiReactionRate
add
age
blendingFactor
components
ddt
div
enstrophy
fieldAverage
fieldMinMax
fieldValueDelta
flowType
grad
histogram
interfaceHeight
log
mag
magSqr
nearWallFields
patchProbes
pressure
probes
processorField
randomise
readFields
scale
sets
streamFunction
streamLine
subtract
surfaceFieldValue
surfaceInterpolate
surfaces
turbulenceFields
turbulenceIntensity
volFieldValue
vorticity
wallHeatFlux
wallShearStress
writeCellCentres
writeCellVolumes
yPlus
[6]
[6]
[6]     From function static Foam::autoPtr<Foam::functionObject> Foam::functionObject::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&)
[6]     in file db/functionObjects/functionObject/functionObject.C at line 100.
[6]
[6]
[7]
[7]
[7] --> FOAM FATAL ERROR:
[7] Unknown function type surfaceRegion
52
CourantNo
Lambda2
MachNo
PecletNo
Q
XiReactionRate
add
age
blendingFactor
components
ddt
div
enstrophy
fieldAverage
fieldMinMax
fieldValueDelta
flowType
grad
histogram
interfaceHeight
log
mag
magSqr
nearWallFields
patchProbes
pressure
probes
processorField
randomise
readFields
scale
sets
streamFunction
streamLine
subtract
surfaceFieldValue
surfaceInterpolate
surfaces
turbulenceFields
turbulenceIntensity
volFieldValue
vorticity
wallHeatFlux
wallShearStress
writeCellCentres
writeCellVolumes
yPlus
[7]
[7]
[7]     From function static Foam::autoPtr<Foam::functionObject> Foam::functionObject::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&)
[7]     in file db/functionObjects/functionObject/functionObject.C at line 100.
[7]
[7]
MPI_ABORT was invoked on rank 1 in communicator MPI COMMUNICATOR 3 SPLIT FROM 0
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[3]
[3] --> FOAM FATAL ERROR:
[3] Unknown function type surfaceRegion
52
CourantNo
Lambda2
MachNo
PecletNo
Q
XiReactionRate
add
age
blendingFactor
components
ddt
div
enstrophy
fieldAverage
fieldMinMax
fieldValueDelta
flowType
grad
histogram
interfaceHeight
log
mag
magSqr
nearWallFields
patchProbes
pressure
probes
processorField
randomise
readFields
scale
sets
streamFunction
streamLine
subtract
surfaceFieldValue
surfaceInterpolate
surfaces
turbulenceFields
turbulenceIntensity
volFieldValue
vorticity
wallHeatFlux
wallShearStress
writeCellCentres
writeCellVolumes
yPlus
[3]
[3]
[3]     From function static Foam::autoPtr<Foam::functionObject> Foam::functionObject::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&)
[3]     in file db/functionObjects/functionObject/functionObject.C at line 100.
[3]
[3]
[taylor-Precision-T1700:04639] 3 more processes have sent help message help-mpi-api.txt / mpi-abort
[taylor-Precision-T1700:04639] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
This is what written to the log file
     \\/     M anipulation  |
Date   : Oct 03 2019
Time   : 08:41:49
PID    : 4645
I/O    : uncollated
nProcs : 8
Slaves :
7
    floatTransfer      : 0
    nProcsSimpleSum    : 0
Create time
Reading field p
Reading field U
Starting time loop
with errorcode 1.
Does anyone have advice on how to fix this? Or whats going on?
tenichols19 is offline   Reply With Quote
Old   October 4, 2019, 08:05
anonymous
When
decomposePar
I get this
     \\/     M anipulation  |
Date   : Oct 03 2019
Time   : 08:41:49
PID    : 4645
I/O    : uncollated
nProcs : 8
Slaves :
7
    floatTransfer      : 0
    nProcsSimpleSum    : 0
Create time
Reading field p
Reading field U
Starting time loop
[0]
[0]
52
CourantNo
Lambda2
MachNo
PecletNo
Q
XiReactionRate
add
age
blendingFactor
components
ddt
div
enstrophy
fieldAverage
fieldMinMax
fieldValueDelta
flowType
grad
histogram
interfaceHeight
log
mag
magSqr
nearWallFields
patchProbes
pressure
probes
processorField
randomise
readFields
scale
sets
streamFunction
streamLine
subtract
surfaceFieldValue
surfaceInterpolate
surfaces
turbulenceFields
turbulenceIntensity
volFieldValue
vorticity
wallHeatFlux
wallShearStress
writeCellCentres
writeCellVolumes
yPlus
[0]
[0]
[0]
[0]
[1]
[1]
52
CourantNo
Lambda2
MachNo
PecletNo
Q
XiReactionRate
add
age
blendingFactor
components
ddt
div
enstrophy
fieldAverage
fieldMinMax
fieldValueDelta
flowType
grad
histogram
interfaceHeight
log
mag
magSqr
nearWallFields
patchProbes
pressure
probes
processorField
randomise
readFields
scale
sets
streamFunction
streamLine
subtract
surfaceFieldValue
surfaceInterpolate
surfaces
turbulenceFields
turbulenceIntensity
volFieldValue
vorticity
wallHeatFlux
wallShearStress
writeCellCentres
writeCellVolumes
yPlus
[1]
[1]
[1]
[1]
[3] [4]
[4]
52
CourantNo
Lambda2
MachNo
PecletNo
Q
XiReactionRate
add
age
blendingFactor
components
ddt
div
enstrophy
fieldAverage
fieldMinMax
fieldValueDelta
flowType
grad
histogram
interfaceHeight
log
mag
magSqr
nearWallFields
patchProbes
pressure
probes
processorField
randomise
readFields
scale
sets
streamFunction
streamLine
subtract
surfaceFieldValue
surfaceInterpolate
surfaces
turbulenceFields
turbulenceIntensity
volFieldValue
vorticity
wallHeatFlux
wallShearStress
writeCellCentres
writeCellVolumes
yPlus
[4]
[4]
[4]
[4]
[5]
[5]
52
CourantNo
Lambda2
MachNo
PecletNo
Q
XiReactionRate
add
age
blendingFactor
components
ddt
div
enstrophy
fieldAverage
fieldMinMax
fieldValueDelta
flowType
grad
histogram
interfaceHeight
log
mag
magSqr
nearWallFields
patchProbes
pressure
probes
processorField
randomise
readFields
scale
sets
streamFunction
streamLine
subtract
surfaceFieldValue
surfaceInterpolate
surfaces
turbulenceFields
turbulenceIntensity
volFieldValue
vorticity
wallHeatFlux
wallShearStress
writeCellCentres
writeCellVolumes
yPlus
[5]
[5]
[5]
[5]
[6]
[6]
52
CourantNo
Lambda2
MachNo
PecletNo
Q
XiReactionRate
add
age
blendingFactor
components
ddt
div
enstrophy
fieldAverage
fieldMinMax
fieldValueDelta
flowType
grad
histogram
interfaceHeight
log
mag
magSqr
nearWallFields
patchProbes
pressure
probes
processorField
randomise
readFields
scale
sets
streamFunction
streamLine
subtract
surfaceFieldValue
surfaceInterpolate
surfaces
turbulenceFields
turbulenceIntensity
volFieldValue
vorticity
wallHeatFlux
wallShearStress
writeCellCentres
writeCellVolumes
yPlus
[6]
[6]
[6]
[6]
[7]
[7]
52
CourantNo
Lambda2
MachNo
PecletNo
Q
XiReactionRate
add
age
blendingFactor
components
ddt
div
enstrophy
fieldAverage
fieldMinMax
fieldValueDelta
flowType
grad
histogram
interfaceHeight
log
mag
magSqr
nearWallFields
patchProbes
pressure
probes
processorField
randomise
readFields
scale
sets
streamFunction
streamLine
subtract
surfaceFieldValue
surfaceInterpolate
surfaces
turbulenceFields
turbulenceIntensity
volFieldValue
vorticity
wallHeatFlux
wallShearStress
writeCellCentres
writeCellVolumes
yPlus
[7]
[7]
[7]
[7]
with errorcode 1.
[3]
52
CourantNo
Lambda2
MachNo
PecletNo
Q
XiReactionRate
add
age
blendingFactor
components
ddt
div
enstrophy
fieldAverage
fieldMinMax
fieldValueDelta
flowType
grad
histogram
interfaceHeight
log
mag
magSqr
nearWallFields
patchProbes
pressure
probes
processorField
randomise
readFields
scale
sets
streamFunction
streamLine
subtract
surfaceFieldValue
surfaceInterpolate
surfaces
turbulenceFields
turbulenceIntensity
volFieldValue
vorticity
wallHeatFlux
wallShearStress
writeCellCentres
writeCellVolumes
yPlus
[3]
[3]
[3]
[3]
     \\/     M anipulation  |
Date   : Oct 03 2019
Time   : 08:41:49
PID    : 4645
I/O    : uncollated
nProcs : 8
Slaves :
7
    floatTransfer      : 0
    nProcsSimpleSum    : 0
Create time
Reading field p
Reading field U
Starting time loop
with errorcode 1.
I should also mention that I only get an error when I attempt to run in parallel..
Old   October 4, 2019, 09:03
Carlo_P
Carlo_P is on a distinguished road
Seems that there's an error in the functionobject.
Are you sure that the same code works in serial?
Maybe the problem is in the decomposition. Maybe the surface is divided in more processors.
I can suggest you to try to run the solver without the functionObjects
I can suggest you to try to use different decomposition methods or setups.
Let me know!
Carlo_P is offline   Reply With Quote
Old   October 4, 2019, 10:44
anonymous
Yes I was able to get it to run.
I tried 2 ways to decompose it.
This was the first way.
|  \\    /   O peration     | Version:  4.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      decomposeParDict;
numberOfSubdomains 8;
method          scotch;
and it seemed to decompose okay. Well it didn't display any errors.
After this didn't work I tried this way.
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
method          simple;
simpleCoeffs
    n               (8 1 1);
    delta           0.001;
hierarchicalCoeffs
    n               (1 1 1);
    delta           0.001;
    order           xyz;
manualCoeffs
    dataFile        "";
distributed     no;
roots           ( );
Could you explain "Maybe the surface is divided in more processors" and "run without the functionObjects"?
What does the functionObjects do?
Thanks for the help.
Old   October 4, 2019, 10:58
Carlo_P
Hey,
seems that your error is linked to the function: surfaceRegion.
Can you check if this function is called your controlDict?
This seems to be the error. I have no idea why this function complain in parallel and not in serial.
I suppose that maybe the surface you are calcolating the value in controlDict has some problems during the decomposition.
Do you have some like this in your controlDict?
surfaceRegion1 { type surfaceRegion; libs ("libfieldFunctionObjects.so"); log true; writeControl writeTime; writeFields true; surfaceFormat none; regionType faceZone; name f0; operation sum; weightField alpha1; fields ( p phi U ); }
Cheers
Old   October 4, 2019, 15:34
anonymous
I have been following this tutorial and he used this as his controlDict.. SurfaceRegion is called in here. https://www.youtube.com/watch?v=2Yfd...Pv0vfw&index=3
Here is the controlDict file.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      controlDict;
application     icoFoam;
startFrom       startTime;
startTime       0;
//stopAt          writeNow;
stopAt          endTime;
endTime         2;
deltaT          0.01;
writeControl    timeStep;
writeInterval   5;
purgeWrite      0;
writeFormat     ascii;
writePrecision  8;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
functions
	minmaxdomain
		type fieldMinMax;
		functionObjectLibs ("libfieldFunctionObjects.so");
		enabled true; //true or false
		mode component;
		writeInterval 1;
		log true;
		fields (p U);
    massFlow_inlet
        type            surfaceRegion;
        enabled         true;
		//writeControl     outputTime;
		writeInterval  1;
        log             true;
        writeFields     false;
        regionType      patch;
        name      	inlet;
	operation       sum;
        fields
            phi
    massFlow_outlet
        type            surfaceRegion;
        enabled         true;
		writeInterval  1;
        log             true;
        writeFields     false;
        regionType      patch;
        name    	outlet;
	operation       sum;
        fields
            phi
I ran the code without the functions and it worked!
Old   October 7, 2019, 04:44
Carlo_P
Ok, so, we found a workaround.
..but seems very strange that it works in serial but not in parallel.
Seems that the library libfieldFunctionObjects.so is not present or doesn't work correctly.
Strange,..
In the end, if you want this function, you can simply reconstruct the latest timestep with reconstruct -latestTime and run on iteration or only the postProcessing (with icoFoam -postProcess) in serial.
error, icofoam -parallel, openfoam
Simulation just stops output writing, but keeps running blaise OpenFOAM Running, Solving & CFD 6 March 27, 2024 04:49
Error problem while running sadia d lts tutorial kane OpenFOAM Running, Solving & CFD 2 May 26, 2018 03:38
Error Running Design of Experiments in ANSYS Fluent tytrzecki FLUENT 0 April 22, 2018 15:01
Problem in running coarse mesh(on the other hand fine mesh is running) ashokmoravaneni OpenFOAM 7 July 17, 2017 04:56
Running Multiple Simulations from Workbench 12.1 Josh CFX 3 August 10, 2010 19:51
