rhoPimpleFoam & fvOptions - defined but not applied |
February 19, 2019, 03:09 |
#1 | ||
Gareth
Rep Power: 15 |
Hi All
I am running a simulation around a heating element. I have a container i would like to see the effect of inlet velocity and outlet placement on the internal temperature of the air. I have a heating element whose temperature i fix with fvOptions. I apply the cellset through topoSet so that i can adjust its location easily. Code:
heatSource { type scalarFixedValueConstraint; active true; selectionMode cellSet; cellSet heater; fieldValues { T 400; } scalarFixedValueConstrainteCoeffs { selectionMode cellSet; } } Code:
thermoType { type hePsiThermo; mixture pureMixture; transport sutherland; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } mixture { specie { molWeight 28.9; } thermodynamics { Cp 1007; Hf 0; } transport { As 1.4792e-06; Ts 116; } } Quote:
February 19, 2019, 04:07 |
#2 | |
Robert
Rep Power: 12 |
Your fvOptions term applies to the variable "T". If you don't have a T variable in your 0/ folder or your solver does not use the T variable from your 0/ folder your fvOptions term does not apply. I just did a quick look-over of the rhoPimpleFoam files and it does not seem to use the T variable.
If you liked my answer to your question, please consider leaving a "Like" in return |
February 19, 2019, 04:15 |
#3 | |
Gareth
Rep Power: 15 |
Hi Robert
Thanks for the reply I am using the angledDuct case as my base. It uses a T field in the 0 folder. Quote:
Which confuses me. I assume T would be included in the rhoPimpleFoma solver but when i looked at he .C file i did not see it. |
February 19, 2019, 06:07 |
#4 | |
Robert
Rep Power: 12 |
Have a look for yourself but i would think that the T file is included to provide BC's and not the variable itself. Thus it does not include the fvOptions term. But i don't work with your solver or anything temperature related. So i might be wrong afterall.
February 19, 2019, 07:45 |
#5 | ||
Gareth
Rep Power: 15 |
Yeah, i saw this post before.
Which makes me think i need to specify enthalpy (h) and not temperature in fvOptions Quote:
Will try the enthalpy approach and let you know |
February 19, 2019, 20:40 |
Rep Power: 14 |
What you're probably looking for is fixedTemperatureConstraint. I've not tested it myself for rhoPimpleFoam, but it is used here (https://github.com/OpenFOAM/OpenFOAM...tant/fvOptions) for a rhoSimpleFoam tutorial so there's no reason it shouldn't work.
Caelan |
April 11, 2019, 10:55 |
Gareth
Rep Power: 15 |
Hi All
Thanks for the info and help. I ended up using an stl (since the heater is a simple box) and then with snappy i assigned a patch name. this name was then use in the T file of my 0 folder to set the temperature. Allowed me to move my heater around easy enough and meant i could set the temperature directly. Cheers |
fvoptions, heat transfer, rhopimplefoam |
Can I use fvOptions to couple a solid region and a fluid region? | titanchao | OpenFOAM Running, Solving & CFD | 4 | January 14, 2022 07:55 |
Adding fvOptions to turbulence model | slottedLemon | OpenFOAM Programming & Development | 13 | May 28, 2020 12:27 |
New output variable for source term in fvoptions - without changing the solver | vincent.clary | OpenFOAM Programming & Development | 2 | June 26, 2018 05:21 |
Transient User Defined Function in CFX | Niru | CFX | 0 | November 12, 2013 17:07 |
What type is defined as the interfaces between stator and stator on OF-2.1.1? | renyun0511 | OpenFOAM Running, Solving & CFD | 3 | May 18, 2013 08:11 |
