Relaxation factors for mass fraction in reactingFOAM |
March 23, 2024, 18:02 |
lisa
Rep Power: 3 |
Hi All! I am trying to set the relaxation factor for the mass fraction equation but can't figure out/find what "name" I should use.
Yi, Y, user-defined specie name don't work. Only when I set relaxationFactors { equations { p 1; U 1; ".*" 0.9; } } it affects the specie mass fraction calculation. But in this case the solution doesn't move at all. So what is the proper way to let the solver know the relaxation factor for the specie mass fraction? |
mass fraction, reacting foam, relaxation factor |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
Under Relaxation Factors | Abdul | CFX | 5 | October 21, 2008 02:16 |
relaxation factors and time accuracy | Mike | Main CFD Forum | 7 | May 21, 2005 12:41 |
