Problem getting oscillations on flow around the cylinder |
April 17, 2019, 07:09 |
Ada Ada
I have this case, flow around cylinder with heat transfer and I am using buoyantPimpleFoam as the solver. I am interested to see oscillations around the cylinder since the flow is turbulent, with Reynolds number of 35 000. I have tried things but it doesnt seems to give any results, I have inletOutlet as the type on U and outletInlet on p and T, I will copy paste them here, thank you for your assistance. FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { rim { type inletOutlet; inletValue uniform (0 1 0); value uniform (0 0 0); } cylinder { type noSlip; } frontAndBack { type empty; } } ------------------------------------------------------------------- FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1e5; boundaryField { rim { type outletInlet; outletValue $internalField; } cylinder { type fixedFluxPressure; } }-------------------------------------------------------------- FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1e5; boundaryField { rim { type outletInlet; outletValue $internalField; } cylinder { type fixedFluxPressure; } } |
Drag force coefficient too high for a flow past a cylinder using komega sst | Scabbard | OpenFOAM Running, Solving & CFD | 37 | March 21, 2016 16:16 |
Problem of convergence- simulation of flow wind around cylinder | activo | FLUENT | 6 | October 23, 2015 01:57 |
Problem of simulating shape oscillations of Bubble - Multiphase flow | akash | FLUENT | 2 | January 29, 2013 13:46 |
Incompressible, Unsteady Cylinder Flow | startingcfd | Main CFD Forum | 1 | March 15, 2011 01:12 |
Turbulent steady flow around a circular cylinder | Mirek Kabacinski | FLUENT | 0 | July 23, 2003 18:40 |
