May 6, 2019, 14:15 |
Outlet boundary conditions (Simflow GUI)
Hello
I'm a beginner in using OpenFOAM, and I'm trying to simulate a heated wall cylinder through which air is flowing. I'm quite unsure on which boundary condition I should use in the outlet, as the "Pressure inlet-outlet velocity" requires me to assume there's no pressure drop and the "inlet-out" I can't understand very well what it is. Any advice? |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
