May 8, 2019, 03:16 |
Parallel processing trouble
odisha
Rep Power: 9 |
I am using OpenFOAM-4.1 and dsmcFoam for my application. I have my own solver which I have added to the dsmc library. I had to change workstation and that is when the problem started with parallel processing. In this new workstation, I get correct results with single processor. But if I try to use parallel processing with 8,9 or 10 processor it does not work. It only works with 5, 7 or 12 processors Case details: I have a 200 X 200 X 1000 porous structure and I decompose it in the z direction only. Then I use dsmcReactionFoam (my own) to get concentration of gas flowing through the porous structure. As it is a very specific kind of issue, I couldn't find any help online. Any help would be appreciated. |
May 20, 2019, 07:00 |
odisha
Rep Power: 9 |
It was due to typecasting a variable wrong.. I initialised a varibale as scalar and it needed to be int.
dsmc, parallelisation |
Parallel processing of OpenFOAM cases on multicore processor??? | g.akbari | OpenFOAM Running, Solving & CFD | 31 | November 1, 2017 09:25 |
foamMonitor in parallel processing | foamingMouth | OpenFOAM Running, Solving & CFD | 0 | September 15, 2016 09:44 |
parallel processing and dynamic mesh | Anand | FLUENT | 0 | January 9, 2009 15:52 |
bubbly flow and parallel processing | mvee | FLUENT | 0 | September 12, 2007 05:08 |
Question about ghost cells in parallel processing | vishwas | Main CFD Forum | 3 | March 12, 2006 21:46 |
