Reynold's number calculation for Laminar and Turbulent flow |
May 22, 2019, 07:37 |
Raza Javed
Rep Power: 7 |
Hello Everyone,
I have a question related to Reynold's number calculation. As we know the relation for Reynold's number: Re=(rho*u*L)/v where rho = density of the fluid (1000 in my case) u = velocity of fluid (1e-3 in my case) L=Diameter of pipe(2.5mm in my case) v= kinematic Viscosity (959e-6 in my case) Using the above values, my Reynolds number turns out to be less than 2300, it means that my flow will be Laminar. But if due to some reasons, the velocity of fluid changes somewhere in the pipe, would it change the fluid flow from Laminar to Turbulent (because as per calculation using the above relation, if velocity increases more than 1.76m/s in my case, then the Re >4000, which means it is Turbulent flow) I am attaching my geometry for your reference. Thank you |
laminar, reynolds number, turbulence |
Reynolds Number (turbulent flow) | soufiane002 | FLUENT | 1 | November 30, 2017 08:16 |
Calculation of Reynold's number - Laminar vs Turbulent flow | DamR | FLUENT | 3 | November 23, 2014 11:23 |
Question regarding Reynolds Number and Turbulent Intensity | maxj | Main CFD Forum | 4 | March 5, 2013 06:16 |
Reynolds and Turbulent flow | Frederic Dubinski | CFX | 5 | October 21, 2004 04:12 |
Reynolds and Turbulent Flow | Frederic Dubinski | Main CFD Forum | 2 | October 20, 2004 13:57 |
