Error in parallel simulation after downgrading from OF6 to OF3.
Old   July 8, 2019, 19:58
Default Error in parallel simulation after downgrading from OF6 to OF3.
Shashank
shashanktiwari619 is on a distinguished road
I use the icoFoam solver for parallel simulation using the decomposePar utility on OpenFoam 6 on the HPC. Lately due to some reason I had to use OF 3.0.1. I observed that the simulations started correctly. However, when I stopped the simulation and restarted them using the latestTime in the controlDict, I got the following error. As you can see it says p file is not present in the decomposed time step due to which it cannot proceed further. I found that as soon as I downgraded from OF 6 to OF 3.0.1, the solver stopped writing p, phi and U files in the decomposed folders. It only writes the field average function that I have asked it to write in my controlDict. Why did it stop writing p, phi and U variables after downgrading. Can you suggest a solution for this?
shashanktiwari619 is offline   Reply With Quote
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 11:58
Parallel Deforming Mesh Simulation Tristan CFX 1 January 28, 2009 17:59
A parallel simulation problem in DPM satum FLUENT 0 October 21, 2008 05:38
How to run parallel simulation on PC with two-CPU? Jimmy FLUENT 1 July 14, 2008 00:46
How to run a parallel simulation? J.Gimbun FLUENT 9 May 24, 2006 05:47
