July 9, 2019, 07:51 |
pimpleFoam suddenly get exit
Milan
Rep Power: 9 |
Hi everyone,
I have been trying to run the pimpleFoam into my propeller case but there has been some error on executing the pimpleFoam after some minutes of execution. Code:
PIMPLE: Iteration 1 AMI: Creating addressing and weights between 37933 source faces and 37933 target faces AMI: Patch source sum(weights) min/max/average = 0.802181, 2.00213, 1.00903 AMI: Patch target sum(weights) min/max/average = 0.000569305, 2.01386, 1.0088 GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.00652399, No Iterations 3 time step continuity errors : sum local = 3.64691e-10, global = 1.50977e-11, cumulative = -2.62063e-09 smoothSolver: Solving for Ux, Initial residual = 0.000880174, Final residual = 7.935e-07, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.000120996, Final residual = 1.37146e-07, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.000929456, Final residual = 6.0459e-07, No Iterations 1 GAMG: Solving for p, Initial residual = 0.0059716, Final residual = 3.85954e-05, No Iterations 4 time step continuity errors : sum local = 5.12401e-11, global = 1.72928e-11, cumulative = -2.60334e-09 GAMG: Solving for p, Initial residual = 0.00229053, Final residual = 4.39153e-07, No Iterations 6 time step continuity errors : sum local = 5.94828e-13, global = 1.61902e-13, cumulative = -2.60317e-09 PIMPLE: Iteration 2 smoothSolver: Solving for Ux, Initial residual = 0.000274223, Final residual = 2.82053e-07, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 3.76589e-05, Final residual = 4.82803e-08, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.000326422, Final residual = 2.12023e-07, No Iterations 1 GAMG: Solving for p, Initial residual = 0.00601082, Final residual = 3.15255e-05, No Iterations 4 time step continuity errors : sum local = 4.2683e-11, global = -1.4213e-11, cumulative = -2.61739e-09 GAMG: Solving for p, Initial residual = 0.00213069, Final residual = 5.31767e-07, No Iterations 6 time step continuity errors : sum local = 7.03291e-13, global = -1.76353e-13, cumulative = -2.61756e-09 smoothSolver: Solving for epsilon, Initial residual = 1.84801e-05, Final residual = 6.1009e-08, No Iterations 1 smoothSolver: Solving for k, Initial residual = 4.95208e-05, Final residual = 1.68352e-07, No Iterations 1 ExecutionTime = 803.14 s ClockTime = 803 s forces forces write: sum of forces: pressure : (-2.94193 36.0195 -30.8047) viscous : (-0.0142583 -0.0344043 -0.0187688) porous : (0 0 0) sum of moments: pressure : (-0.341646 -29.0562 -3.71919) viscous : (4.3322e-05 -0.0234912 0.00595161) porous : (0 0 0) Courant Number mean: 0.000539523 max: 0.998274 deltaT = 3.63716e-06 Time = 0.000137992 PIMPLE: Iteration 1 AMI: Creating addressing and weights between 37933 source faces and 37933 target faces AMI: Patch source sum(weights) min/max/average = 0.796835, 2.02346, 1.00927 AMI: Patch target sum(weights) min/max/average = 0, 2.043, 1.00903 GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.00642757, No Iterations 3 time step continuity errors : sum local = 3.65445e-10, global = 1.45006e-11, cumulative = -2.60306e-09 smoothSolver: Solving for Ux, Initial residual = 0.000874066, Final residual = 7.71885e-07, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.00011986, Final residual = 1.32681e-07, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.000931321, Final residual = 5.87728e-07, No Iterations 1 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? #5 ? at ??:? #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? at ??:? Floating point exception (core dumped) ***Max skewness = 7.68338, 60 highly skew faces I have been trying to run it in both serial and parallel but non of this work. Same problem reoccur. what could be the possible error to this? I don't know whether the problem arise because of skewness or something else. I am working in a project and there is no one to help me in OpenFOAM. This is only one option where I could ask for some help. Thank you. Best regards, |
July 9, 2019, 10:50 |
Kmeti Rao
Rep Power: 8 |
Hi Milan,
Go through this link Skewness Problems. Here they have mentioned what are the effects of having skewness and also how to visualize and overcome it. Try to always produce good and quality mesh. Also, go through this link you will learn a lot to tackle some basic issues in OpenFOAM http://www.wolfdynamics.com/wiki/OFtipsandtricks.pdf. Hope it helps. Krao |
July 11, 2019, 01:07 |
#3 | |
Milan
Rep Power: 9 |
Thank you for the support and reminding me to go through wolfDyanmics files. |
ami, foam::error::printstack, pimplefoam |
delta T decreases suddenly in pimplefoam | 1988 | OpenFOAM Running, Solving & CFD | 10 | June 28, 2014 01:34 |
back pressure at exit for supersonic flow | BigFrank | FLUENT | 6 | April 24, 2014 15:13 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
Pressure drop and exit velocity | mejahan | CFX | 6 | August 4, 2013 16:57 |
