Oscillation in mesh refinement and unrefinement |
August 24, 2019, 08:17 |
Oscillation in adaptive mesh refinement
krishna kant
Rep Power: 10 |
Hello Foamers,
I am using dynamicMeshRefinement of OpenFoam and solving a static bubble test case. I am observing that a fix number of cell (i.e. 64) is getting refined and unrefined alternatively with the passage of time. Have anyone observed something like this before? What is the cause and remedy for this? Last edited by kk415; August 31, 2019 at 04:06. |
August 31, 2019, 04:11 |
krishna kant
Rep Power: 10 |
Hello Foamers,
I am attaching my output for your reference. Courant Number mean: 1.69912e-07 max: 7.16164e-06 Interface Courant Number mean: 1.9221e-08 max: 6.04455e-06 Time = 0.09999 PIMPLE: iteration 1 Selected 112 cells for refinement out of 34896. Refined from 34896 to 35680 cells. Selected 0 split points out of a possible 1920. Execution time for newMesh.update() = 0.44 s Defining the group of the cells MULES: Solving for alpha.water Phase-1 volume fraction = 0.0316 Min(alpha.water) = 0 Max(alpha.water) = 1 solve the reinitialization equation Interpolation of psi from coarser to finer mesh Solve the modified reinitialization equation in finer mesh Interpolation from finer to coarser mesh Interpolation from finer to coarser mesh Interpolation from finer to coarser mesh MULES: Solving for alpha.water DICPCG: Solving for p_rgh, Initial residual = 0.0100551, Final residual = 9.51849e-08, No Iterations 209 time step continuity errors : sum local = 2.11276e-14, global = -1.03739e-25, cumulative = 1.13937e-23 ExecutionTime = 115367 s ClockTime = 115435 s Courant Number mean: 1.70292e-07 max: 7.16211e-06 Interface Courant Number mean: 1.92162e-08 max: 6.04469e-06 Time = 0.099995 PIMPLE: iteration 1 Selected 0 cells for refinement out of 35680. Selected 112 split points out of a possible 1920. Unrefined from 35680 to 34896 cells. Execution time for newMesh.update() = 0.4 s Defining the group of the cells MULES: Solving for alpha.water Phase-1 volume fraction = 0.0316 Min(alpha.water) = 0 Max(alpha.water) = 1 solve the reinitialization equation Interpolation of psi from coarser to finer mesh Solve the modified reinitialization equation in finer mesh Interpolation from finer to coarser mesh Interpolation from finer to coarser mesh Interpolation from finer to coarser mesh MULES: Solving for alpha.water DICPCG: Solving for p_rgh, Initial residual = 0.0100496, Final residual = 9.16363e-08, No Iterations 220 time step continuity errors : sum local = 2.02673e-14, global = -3.25376e-25, cumulative = 1.10683e-23 ExecutionTime = 115375 s ClockTime = 115443 s Courant Number mean: 1.69908e-07 max: 7.16148e-06 Interface Courant Number mean: 1.92202e-08 max: 6.04428e-06 Time = 0.1 PIMPLE: iteration 1 Selected 112 cells for refinement out of 34896. Refined from 34896 to 35680 cells. Selected 0 split points out of a possible 1920. Execution time for newMesh.update() = 0.43 s Defining the group of the cells MULES: Solving for alpha.water Phase-1 volume fraction = 0.0316 Min(alpha.water) = 0 Max(alpha.water) = 1 solve the reinitialization equation Interpolation of psi from coarser to finer mesh Solve the modified reinitialization equation in finer mesh Interpolation from finer to coarser mesh Interpolation from finer to coarser mesh Interpolation from finer to coarser mesh MULES: Solving for alpha.water DICPCG: Solving for p_rgh, Initial residual = 0.0100549, Final residual = 9.61359e-08, No Iterations 209 time step continuity errors : sum local = 2.13378e-14, global = -1.83658e-25, cumulative = 1.08847e-23 ExecutionTime = 115383 s ClockTime = 115451 s This problem is increasing my computational time and I am losing the advantage of AMR. |
simpleDyMFoam on v1806 | gamemakerh | OpenFOAM Programming & Development | 0 | November 8, 2018 08:15 |
Error when combining mesh re-distribution with refinemt | rribeiro | OpenFOAM Programming & Development | 0 | March 24, 2015 14:47 |
