gradient term in buoyantBoussinesqPimpleFoam
Old   October 21, 2019, 11:20
Default gradient term in buoyantBoussinesqPimpleFoam
Reviewer #2
randolph is on a distinguished road
In the buoyantBoussinesqPimpleFoam, the gradient of pressure and the density term is calculated as the following. In my understanding, the surface normal gradient is first calculated and then used to reconstruct the gradient.
   solve
             UEqn
             fvc::reconstruct
                   - ghf*fvc::snGrad(rhok)
                   - fvc::snGrad(p_rgh)
                 )*mesh.magSf()
My question is why not just simply calculating the gradient as:
-fvc::grad(p_rgh)
Are these two approaches equivalent? If not, why is the first approach better than the second?
Thanks,
Rdf
randolph is offline   Reply With Quote
Source Term due to evaporation in energy transport equation styleworker OpenFOAM Programming & Development 3 September 7, 2022 03:09
Source term for EVAPORATION in Energy Equ. - technical difficulty ? Kummi OpenFOAM 1 September 9, 2019 09:32
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 05:35
problem with gradient as source term in coupled equations Cyp OpenFOAM Programming & Development 0 August 16, 2010 13:12
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 10:52
