Tutorial offSetCylinder gives unexpected result
Old   November 26, 2019, 04:23
Default Tutorial offSetCylinder gives unexpected result
Jean bon
FlyingCat is on a distinguished road
Hello everybody,
I ran the tutorial offSetCylinder with OpenFOAM-7 and I do not understand the results.
Without changing any parameter, the solution at the first time step (0.001 s) is given in the attached figure. This could be correct with simpleFoam but I ran pimpleFoam.
According to the simulation, the flow crosses the whole domain in 1 ms. This does not depend on the time step (1e-6 yields the same result).
If I change the boundary condition on the left from Neumann to Dirichlet on the pressure (P=0), then the flow slowly propagates, which better represents reality. But enforcing two Dirichlet boundary conditions on the pressure and velocity on the same boundary leads to oscillations of both variables.
I think this is a numerical issue since enforcing zero Neumann condition on the pressure should not yield a infinitely fast propagation of the flow. Does someone have an idea about this matter ?
Thank you
FlyingCat is offline   Reply With Quote
Old   November 28, 2019, 03:22
Jean bon
Could the problem be a known mathematical behaviour (that I do not know) ?
Indeed, does the use of such boundary conditions lead to a uniform flow in the whole domain because it is the mathematical solultion of the incompressible Navier-Stokes equations ? If so, how to model the development of an incompressible jet flow for instance ?
Thank you
Sandia Flame D OpenFoam tutorial case - bad result? Brandani OpenFOAM Programming & Development 8 January 18, 2022 13:29
[snappyHexMesh] The snappyMultiRegionHeater tutorial does not snap correctly wildfire230 OpenFOAM Meshing & Mesh Conversion 2 May 10, 2019 06:19
Read Result Files or User Defined Result Aquilaris ANSYS 0 February 9, 2011 05:25
STAR-CD Tutorial shekhar aryal STAR-CD 4 March 22, 2010 03:25
Rotor/stator tutorial, and how to... gilberto CFX 5 January 21, 2002 09:41
