Positive or negative values of Lambda2 for vortex structure visualization? |
May 8, 2017, 09:10 |
vidyadhar
Rep Power: 9 |
I want to visualize the vortex structures in the flow through a pipe junction having square cross-section.
If I select negative value of Lambda-2 criterion in paraview, I find structures near the walls. For positive values of Lambda2, the structures are away from the walls. Also, I am getting same pattern of vortex structures with positive values of Lambda2 which I do get with positive value of Q criterion. So, 1) should I select positive values of Lambda2 or negative values? 2)Do Q- and Lambda2- criteria give similar structures? Thanks in advance!!! |
November 26, 2019, 23:12 |
Jianrui Zeng
Rep Power: 8 |
I am still interested in this topic. Can anyone describe more details about Q- or lambda-2 criterium. Can I just use postProcess -func Lamdba2 to calculate it and visualized it through paraview ?
November 27, 2019, 00:45 |
#3 | |
vidyadhar
Rep Power: 9 |
Hello Zeng, You may find other suitable answers also. Any way you may please look at 1.https://www.researchgate.net/post/Po...confined_flows 2. https://www.researchgate.net/post/Ho...n_Ansys_Fluent Last edited by vidyadhar; November 27, 2019 at 04:06. |
November 27, 2019, 08:03 |
#4 | |
Jianrui Zeng
Rep Power: 8 |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
Fluid Structure interface - Negative Volume | mohammad.cheikh | FLUENT | 2 | January 23, 2014 14:49 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
positive and negative torque forces | Wei-Haur Lam | CFX | 0 | March 19, 2008 07:45 |
How to enforce positive values | Ning | Main CFD Forum | 10 | August 20, 2000 00:10 |
