The pressure equation in reactingFoam and rhoReactingFoam
Like Tree4Likes
  • 2 Post By cryabroad
  • 1 Post By cryabroad
  • 1 Post By holmej
Old   December 29, 2019, 02:28
Default The pressure equation in reactingFoam and rhoReactingFoam
Ruiyan Chen
cryabroad is on a distinguished road
Hello Foamers,
As far as I understand, the two solvers reactingFoam and rhoReactingFoam differ ONLY in the way how the density is calculated. One is calculated from psi*p and one is directly accessed from the thermodynamics library (By the way is this true?). They are both pressure-based solvers, because they both solve a pressure equation to satisfy the continuity equation.
However, their pressure equations are different. I also notice that starting from OpenFOAM-5.x, the pressure equation in rhoReactingFoam is the same as the one in rhoPimpleFoam. But before that, the pressure equation in reactingFoam is the same as the one in rhoPimpleFoam. I basically have two questions: 1. Why the pressure equation is different in reactingFoam and rhoReactingFoam? Aren't they solving the same pressure equation? 2. How is rhoReactingFoam (or reactingFoam) connected to rhoPimpleFoam? I would think that with reaction turned off, these three should be the same thing.
Thanks in advance,
Ruiyan
cryabroad is offline   Reply With Quote
Old   December 29, 2019, 07:46
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Would you mind to give snippets of the differences, otherwise quite difficult to follow?
HPE is offline   Reply With Quote
Old   December 29, 2019, 21:06
Ruiyan Chen
Hi HPE, thank you for your interest! I should've done that to make myself more clear. Take OpenFOAM-6 for example, the relevant code are as follows.
From the pEqn.H in rhoReactingFoam (and rhoPimpleFoam)
if (!pimple.simpleRho())
rho = thermo.rho();
// Thermodynamic density needs to be updated by psi*d(p) after the
// pressure solution
const volScalarField psip0(psi*p);
code that are not relevant
else
fvScalarMatrix pDDtEqn
fvc::ddt(rho) + psi*correction(fvm::ddt(p))
+ fvc::div(phiHbyA)
fvOptions(psi, p, rho.name())
while (pimple.correctNonOrthogonal())
fvScalarMatrix pEqn(pDDtEqn - fvm::laplacian(rhorAUf, p));
pEqn.solve(mesh.solver(p.select(pimple.finalInnerI ter())));
if (pimple.finalNonOrthogonalIter())
phi = phiHbyA + pEqn.flux();
// Thermodynamic density update
thermo.correctRho(psi*p - psip0);
and from the pEqn.H in reactingFoam
rho = thermo.rho();
else
surfaceScalarField phiHbyA
"phiHbyA",
fvc::flux(rho*HbyA)
+ MRF.zeroFilter(rhorAUf*fvc::ddtCorr(rho, U, phi))
MRF.makeRelative(fvc::interpolate(rho), phiHbyA);
// Update the pressure BCs to ensure flux consistency
constrainPressure(p, rho, U, phiHbyA, rhorAUf, MRF);
fvScalarMatrix pEqn
fvm::ddt(psi, p)
+ fvc::div(phiHbyA)
If I understand it correctly, the difference is the additional psi*correction(fvm::ddt(p)) term used in rhoReactingFoam. However, this seems to be coming from the fact that rho = psi * p (which is the basis of all psi-based thermodynamics in FOAM), and if we take psi as a constant within the iteration, then we have rho_new-rho_old = psi*(p_new-p_old).
The pressure equation in reactingFoam seems natural and easy to understand. It is just a Poisson's equation where rho does not appear explicitly because of the fact that rho = psi * p. However, the pressure euqation in rhoReactingFoam involves a fvc::ddt(rho) term, which is explicit, and the correction term I mentioned above. Why can't we use the same Poisson's equation as that in reactingFoam? I feel like I'm missing some obvious things here and it could be very obvious to other people.
And one more thing, if I run a same case with these two solvers, it should give me the exact same results right? In other words, in terms of the ability of modelling the physics, these two should be identical, or maybe one is better than the other under some extreme conditions? Sorry for my lengthy statements/questions above, as I'm getting picky about every detail since I started using FOAM, dare I say it's kind of addictive.
R.Mah and Weitao like this.
Old   January 3, 2020, 03:13
Ruiyan Chen
Anyone? Still waiting for some answers/discussions here.
R.Mah likes this.
Old   January 19, 2024, 10:03
holmej is on a distinguished road
Four years have passed, can anyone have a clearer understanding of this issue and share it? I would appreciate it.
holmej is offline   Reply With Quote
Old   January 20, 2024, 02:02
Domenico Lahaye
dlahaye is on a distinguished road
One element in the discussion might be the fact that reactingFoam is able to solve flows that are not incompressible.
Understanding the pressure equation in reactingFoam might thus involve two steps:
1/ step 1/2: understand how the pressure equation changes when passing from incompressible constant density flow (say simpleFoam) to still incompressible, but now variable density flow (say buoyantSimpleFoam). The energy equation and the thermodynamics (equation of state) needs to be taken into account.
2/ step 2/2: understand how the pressure equation changes when passing from incompressible variable density flow to no longer incompressible flows. The book of e.g. Darwish-Mangani-Moukalled gives a good theoretical basis. Having settled that basis, one can discuss what happens in the implementation.
dlahaye is offline   Reply With Quote
Old   January 20, 2024, 05:26
Thanks for your reply. But different version of the OF have distinguished equations about the reactingFoam and rhoReactingFoam, so I need more time to figure out which solver is suitable for compressible reaction flow.Thank you again.
Old   January 21, 2024, 04:59
Domenico Lahaye
In most recent versions of OF, reactingFoam and rhoReactingFoam have merged into reactingFoam.
If flow is compressible, make sure to set transonic on in system/controlDict.
Old   January 21, 2024, 06:45
Yes, you are right. In OF V9, these two solvers had been merged. The "transonic" you mentioned seems to be effective in simple flow without combustion. I'm not familiar with OF. If I am wrong, please point it out.
Old   January 21, 2024, 07:06
Domenico Lahaye
What do you mean by "effective" in this context?
Old   January 21, 2024, 07:35
I'm sorry for unclear expression. I mean "transonic" switch only appear in the tutorials without combustion, like rhoCentralFoam. Tutorials of reactingFoam have no option about "transonic".
Old   January 21, 2024, 10:06
Domenico Lahaye
What follows could merely be my points of view. The transonic options belongs to a solver like reactingFoam, more than to a tutorial case.
I do know at Mach number e.g. the chokedNozzle or membrane tutorial case are set. One could merely change the inlet velocity, vary the Mach number and verify how reactingFoam behaves with transonic set either on or off.
Not sure whether this addresses your concern.
Old   January 21, 2024, 11:01
Thank you for providing the idea. It is a way to verify whether the reactingFoam acts like compressible solvers with transonic or supersonic conditions.
Old   January 21, 2024, 12:43
Domenico Lahaye
Pls beware that changing the combustion/reactingFoam/RAS tutorial cases from incompressible to transonic (by increasing e.g. the mass flow rate of the fuel) might require changing the boundary conditions for the pressure. We have found the wave transmissive boundary conditions at the outlet to work well. Good luck.
Old   January 21, 2024, 13:09
You are a kind man. Thank you for your advice!
dlahaye likes this.
Difference between reactingFoam & rhoreactingfoam upadhyay.1 OpenFOAM Programming & Development 8 October 13, 2022 09:42
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 12:30
compressible, reacting nozzle flow rhoReactingFoam hughmorgan OpenFOAM Running, Solving & CFD 1 September 26, 2016 08:08
reactingFoam vs rhoReactingFoam Scot OpenFOAM Running, Solving & CFD 8 June 2, 2016 11:28
Bug in rhoReactingFoam francesco_capuano OpenFOAM Bugs 2 February 6, 2012 15:11
