Abnormal velocity when modelling wall boiling using reactingTwoPhaseEulerFoam
Old   January 20, 2020, 08:43
Default Abnormal velocity when modelling wall boiling using reactingTwoPhaseEulerFoam
ZZW
Zhao
ZZW is on a distinguished road
Hi Foamers,
I am modelling water-vapour wall boiling inside a vertical pipe, using a wedge asymmetric mesh. The length is 2m, with 15.4 mm diameter.
Pipe wall heat flux is 570000w.m-2 and the average velocity at the inlet is 1m.s-1, working at 45 bar pressure. Turbulence model for both phases is k-epsilon.
The simulation runs good at the beginning, but when the vapour volume fraction be closing to 0.1 the max velocity increases rapidly to around 3m.s-1, and then the volume fraction as well.
For reference, I have attached some files here. If my question is unclear, please let me know in the comment.
Regards,
Zao
Liquid velocity code:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U.liquid;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 1);
boundaryField
    inlet
        type            mapped;
        field           U.liquid;
        setAverage      1;
        average         (0 0 1);
        interpolationScheme cell;
        value           uniform (0 0 1);
    outlet
        type            pressureInletOutletVelocity;
        phi             phi.liquid;
    wall
        type            noSlip;
    front
        type            wedge;
    back
        type            wedge;
alphat.liquid code:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      alphat.liquid;
dimensions      [1 -1 -1 0 0 0 0];
internalField   uniform 1e-8;
boundaryField
    inlet
        type            calculated;
        value           uniform 1e-8;
    outlet
        type            calculated;
        value           uniform 1e-8;
    wall
        type            compressible::alphatWallBoilingWallFunction;
        otherPhase      gas;
        phaseType       liquid;
        Prt             0.85;
        /*Cmu             0.09;
        kappa           0.41;
        E               9.8;
        relax           0.01;
        dmdt            uniform 0;*/
        partitioningModel
            type        Lavieville;
            alphaCrit   0.2;
        nucleationSiteModel
            type        LemmertChawla;
        departureDiamModel
            type        TolubinskiKostanchuk;
        departureFreqModel
            type        Cole;
        value           uniform 0.01;
    front
        type           wedge;
    back
        type            wedge;
ZZW is offline   Reply With Quote
Old   January 31, 2020, 16:06
ZZW
Zhao
Reason found.
mu coefficients is supposed to be corrected as:
 transport
        muCoeffs<8>  (0.0004282 -6.19667e-7 0 0 0 0 0 0);
        kappaCoeffs<8> (1.14518355 -0.001017 0 0 0 0 0 0);
Old   February 15, 2020, 10:59
Tolu
skizzz is on a distinguished road
where did you get the coefficients from
skizzz is offline   Reply With Quote
reactingtwophaseeulerfoam, wall boiling
UDF comilation error. urgent help please m zubair Fluent UDF and Scheme Programming 4 February 10, 2019 11:19
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
wall velocity in remeshing case mahdinili CFX 1 June 7, 2012 18:49
Problem Interface Solid Fluid with wall velocity Solver v12 hills1 CFX 2 October 12, 2009 05:36
