Sum of mass fractions is zero for species 6(NO NH3 O2 CO2 N2 H2O)
Like Tree1Likes
  • 1 Post By houss
Old   January 28, 2021, 09:20
Default Sum of mass fractions is zero for species 6(NO NH3 O2 CO2 N2 H2O)
Davyd is on a distinguished road
Hello.
I am trying to do simulation of the gas-solid fluidized bed catalytic reactor. For this purpose I use tutorial reactingTwoPhaseEulerFoam--->laminar--->fluidisedBed. However, since it does not contain any files responsible for chemistry, I use chemistry files from combustion tutorial--->chemFoam--->h2. Of course I have modified them according to my case (reaction, species, conditions).
When I start simulation I get the ERROR described below, however it seems that I have defined the mole fractions for species. You can find the files responsible for chemistry attached to this thread.
Please, if someone knows how to overcome this issue, give me your advice. Thank you for your help!!!
Best,
Davyd.
| \\ / O peration | Version: v1912 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
Build : _f3950763fe-20191219 OPENFOAM=1912
Arch : "LSB;label=32;scalar=64"
Exec : reactingTwoPhaseEulerFoam
Date : Jan 28 2021
Time : 15:44:49
Host : LAPTOP-LTH2ON9V
PID : 1922
I/O : uncollated
Case : /mnt/c/Users/David/Downloads/OpenFOAM/OpenFOAM-v1912/RUN/fluidisedBed_REACTING_comb_h2
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: no residual control data found. Calculations will employ 3 corrector loops
Reading g
Reading hRef
Creating phaseSystem
Selecting twoPhaseSystem interfaceCompositionPhaseChangeTwoPhaseSystem
Selecting phaseModel for particles: purePhaseModel
Selecting diameterModel for phase particles: constant
Selecting thermodynamics package
type heRhoThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState rhoConst;
specie specie;
energy sensibleInternalEnergy;
Calculating face flux field phi.particles
Selecting turbulence model type RAS
Selecting RAS turbulence model phasePressure
phasePressureCoeffs
preAlphaExp 500;
expMax 1000;
alphaMax 0.62;
g0 1000;
Selecting phaseModel for air: reactingPhaseModel
Selecting diameterModel for phase air: isothermal
type heRhoThermo;
mixture reactingMixture;
transport sutherland;
thermo janaf;
equationOfState perfectGas;
specie specie;
energy sensibleEnthalpy;
Selecting chemistryReader chemkinReader
--> FOAM FATAL ERROR:
From function void Foam::multiComponentMixture<ThermoType>::correctMa ssFractions() [with ThermoType = Foam::sutherlandTransport<Foam::species::thermo<Fo am::janafThermo<Foam:erfectGas<Foam::specie> >, Foam::sensibleEnthalpy> >]
in file lnInclude/multiComponentMixture.C at line 64.
FOAM exiting
File Type: txt chem.inp.txt (139 Bytes, 22 views)
File Type: txt senk.inp.txt (190 Bytes, 17 views)
Davyd is offline   Reply With Quote
Old   August 31, 2021, 10:09
Hosam Alrefaie
HosamAlrefaie is on a distinguished road
Hi Davyd, did find how to add the mass fractions of the species?
I am using multiComponentMixture with buoyantSimpleFoam, but I don't know where to add the mass fractions.
HosamAlrefaie is offline   Reply With Quote
Old   August 15, 2022, 13:18
Houssam
houss is on a distinguished road
Send a message via Skype™ to houss
hello!
i am facing the same issue with reactingFoam? have you guys been able to overcome the problem?
houss is offline   Reply With Quote
Old   August 15, 2022, 15:29
Houssam
for those who may encounter the problem :
the initial value of the internalField of one of the specie files (CH4, CO2 O2 N2 or H2O) must be set to one. Same thing for the initial value at the outlet
outlet
type inletOutlet;
inletValue uniform 0;
value uniform 1;
Petey likes this.
Old   April 9, 2024, 20:58
Moises Sena
senammoises is on a distinguished road
Originally Posted by houss View Post
hello!
hey did you find the solution? I'm facing the same problem with reactingFoam
senammoises is offline   Reply With Quote
Old   April 9, 2024, 20:59
Moises Sena
outlet
type inletOutlet;
value uniform 1;
I did that but it didn't work
Old   April 10, 2024, 04:01
Krapf is on a distinguished road
Is it possible for you to upload your case? If not, then please upload the files in the 0 folder (with the information about which species you are using).
Krapf is offline   Reply With Quote
Old   April 10, 2024, 08:43
Moises Sena
Originally Posted by krapf View Post
is it possible for you to upload your case? If not, then please upload the files in the 0 folder (with the information about which species you are using).
C5H6.txt
C10H12.txt
Old   April 10, 2024, 10:10
For "inletPilot" and "inletAir", the values for "value" must add up to 1 and for "outlet", the values for "inletValue" must add up to 1.
Old   April 10, 2024, 10:36
Moises Sena
thank you!! It worked!!!
One more question:
I starting to use reactingFoam and now successfully I inputed a new reaction, started from the Sandia tutorial. Now I want to change the geometry.
Which steps should I follow to change the geometry?
I already have the mesh (a .unv file).
thank you once again
Old   April 11, 2024, 04:06
There is the command "ideasUnvToFoam" (I have never used it): https://www.openfoam.com/documentati...UnvToFoam.html.
But if you don't know how to use your own geometry, you might want to take a step back and look at tutorials first (you can find some here, for example: https://wiki.openfoam.com/Tutorials).
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 5, 2023 23:48
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 09:10
p_rgh initial residual no change with different settings manuc OpenFOAM Running, Solving & CFD 3 June 26, 2018 15:53
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
species mass fractions Mark Austin FLUENT 0 October 28, 2004 13:46
