OpenFOAM first simulation project
Old   February 16, 2020, 15:36
Default OpenFOAM first simulation project
hityo is on a distinguished road
Hey Foamers,
I am trying this first 2D simulation in OpenFoam and I want to know your expert opinion how should approach it.
I have to find Volumerate at Outlet.
I am thinking of incompressible, turbulent simulation.
Where should I give 50 Pa as a inlet Boundary condition if all others are wal
hityo is offline   Reply With Quote
Old   February 18, 2020, 04:43
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
  • Create you mesh (blockMesh/Salome/other software)
  • Use setFields to initialize the pressure value (50 Pa) inside the room
  • set the pressure outside the room to fixedvalue = 0 Pa
  • Use pressure related boundary conditions for U outside the room
  • Use pimpleFoam (or pisoFoam / icoFoam / what you prefer - Pimple is recommended)
  • Done
Depending on the velocity and so on, you should check if compression is a phenomenon to capture. If so, you should use a density based solver rather than a pressure based one.
Also change the transportProperties to your specific fluid and set the turbulent model according to your needs.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   March 2, 2020, 09:28
Thank you for the Reply!
I am trying to do a steady state simulation so simpleFoam is the obvious choice ?
Old   March 3, 2020, 06:46
Vignesh Veeresparan
Vignesh Veeresparan is on a distinguished road
Are you trying to do steady state compressible or steady state in compressible flow?
If steady state compressible use rhoSimpleFoam else simpleFoam.
Hope i answered your question.
Vignesh Veeresparan is offline   Reply With Quote
beginners, boundary condition, openfoam 17.06(v2)
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 08:51
OpenFoam - Simulation suddenly stops, reactingFoam Vittorio94 OpenFOAM Programming & Development 2 June 25, 2019 03:02
OpenMPI error at the beginnin of parallel OpenFOAM Simulation tre95 OpenFOAM Programming & Development 2 June 17, 2019 06:36
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
