Mesh motion with fine mesh yields instabilities |
Jean bon
Rep Power: 9 ![]() |
I am trying to simulate a 3D fluid-structure interaction problem. The problem corresponds to an airfoil (chord=8 cm) in water (1 m/s). The mesh consists in 15 M of cells. The boundary layer is meshed with approximately 20 cells (I cannot do better with cfMesh and SnappyHexMesh). I ran the fluid simulation (without interaction with the airfoil) and had consistent results (until 1 sec, then I stopped). Now, I would like to run the case with the deformation of the solid. I am using preCICE and CalculiX as the interface coupling and the solid software code. They work perfectly and the question does not concern them. With a CFL of 0.3, with or without the boundary layer mesh, the fluid-structure simulation diverges. After 15 time steps (dt=1e-5), the velocity increases up to 3 m/s below the airfoil, at the first boundary cells whereas the displacement is smaller than 0.02 mm. I tried smaller time steps but I cannot use smaller than 1e-6 seconds due to the calculation time. And the problem remains even if the velocity diverges further (30 times steps for dt=5e-6 s and no boundary layer mesh). So my question is, is it possible to run a 3D simulation of an incompressible fluid, which is based on a fine mesh, with mesh motion? Does this mean that I must either decrease the time step or coarsen the mesh? Sorry, I cannot share any picture due to containment. Thank you |
Moving Reference Frame + Mesh Motion | @sher | FLUENT | 0 | May 9, 2019 04:22 |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 04:27 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Update of the variables after dynamic mesh motion. | gtg258f | OpenFOAM Programming & Development | 9 | January 18, 2014 10:08 |
Different zone motion and mesh motion preview | aamer | FLUENT | 5 | September 24, 2012 13:58 |
