May 18, 2020, 20:49 |
simulating a grain storage bin
Matt Schramm
I would like to perform an aeration simulation of grain in a bin but I am not sure on the solver(s) that would work for me. I have been using OpenFOAM-5.x. I made a simple silo (cylinder with a cone on top) in gmsh. I labeled the surfaces of the silo (bottom, top, sidewalls, conewalls). I also labeled the two volumes grain (the cylinder portion), and air (the cone portion). I believe I need to do this for porousSimpleFoam and the rhoPorousSimpleFoam solvers (should only need porousSimpleFoam as I should be able to assume incompressible flow). If I understand things correctly, I could also use fvmOptions and add a porous region with differing solvers. Is there a way to add this a different way? Like would I be able to "cut" this porous region to add a box in the middle of the porous region? Is it "right" to have the porous region touching the inlet of the simulation? I have been playing with the pimpleFOAM porous blockage simulation and very weird things happen when the "porous" region touches the boundaries but this is what happens in a grain silo. I also want to track the moisture content in the grain. Can this be done via a species or is there a ready built solver that couples moisture and temperature? Using the gmsh to openFoam utility, I get a defaultFaces patch/wall. How can I remove this as it is not a "real" face, or what boundary conditions are needed? This defaultFace is located between the "grain" and "air" volumes. Any and all help would be appreciated. I can also supply my test case if that can be beneficial. |
bin data gives wrong data | Paul F. | OpenFOAM Post-Processing | 0 | February 24, 2017 07:18 |
The udf.h headers are unable to open- in VISUAL STUDIO 13 | sanjeetlimbu | Fluent UDF and Scheme Programming | 4 | May 2, 2016 05:38 |
Stability and Realibility of microfluidic droplets storage in tube or storage coil | devalvyas | System Analysis | 0 | February 2, 2016 11:49 |
Need Help Simulating Hydrogen Storage in Metal Hydride | jehadyam | CFD Freelancers | 0 | January 29, 2013 16:41 |
Problem with UDF compiling for kTkLW model | Wantami | FLUENT | 0 | July 18, 2011 05:11 |
