May 26, 2020, 16:18 |
libcodeStream error
Rep Power: 9 |
Hello Everyone,
I'm running an openfoam case in which trying to set alpha values in some areas. my alpha.water code is as follows: /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object alpha.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField #codeStream { codeInclude #{ #include "fvCFD.H" #}; codeOptions #{ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude #}; codeLibs #{ -lmeshTools \ -lfiniteVolume #}; code #{ const IOdictionary& d = static_cast<const IOdictionary&>(dict); const fvMesh& mesh = refCast<const fvMesh>(d.db()); scalarField alpha(mesh.nCells(), 0.); scalar m = 3; scalar l = 0.01; scalar x_m = 0.2; forAll(alpha, i) { const scalar x = mesh.C()[i][0]; const scalar y = mesh.C()[i][1]; if (x <= 0.1) { //if (x < x_m*(cos(constant::mathematical:i*2*m*y/l)-1)) //{ //alpha[i] = 1.; //} alpha[i] = 1.; } } alpha.writeEntry("", os); #}; }; boundaryField { leftWall { type zeroGradient; } rightWall { type zeroGradient; } topWall { type zeroGradient; } bottomWall { type zeroGradient; } inlet { type fixedValue; value uniform 1;//only water enters the domain } outlet { type inletOutlet; inletValue uniform 0; value uniform 0; } defaultFaces { type empty; } } // ************************************************** *********************** // But when I run paraFoam to see the grids etc. I got the following error: paraFoam Created temporary 'HeleShaw.OpenFOAM' I/O : uncollated Using #codeStream at line 19 in file "/home/sajjad/OpenFOAM/sajjad-7/run/HeleShaw/0/alpha.water" Using #codeStream with "/home/sajjad/OpenFOAM/sajjad-7/run/HeleShaw/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_ea12f2a39247c277bbdd1fe0e3c42522d406 9843.so" Invoking "wmake -s libso /home/sajjad/OpenFOAM/sajjad-7/run/HeleShaw/dynamicCode/_ea12f2a39247c277bbdd1fe0e3c42522d4069843" wmake libso /home/sajjad/OpenFOAM/sajjad-7/run/HeleShaw/dynamicCode/_ea12f2a39247c277bbdd1fe0e3c42522d4069843 Ctoo: codeStreamTemplate.C /home/sajjad/OpenFOAM/sajjad-7/run/HeleShaw/0/alpha.water.#codeStream: In function 'void Foam::codeStream_ea12f2a39247c277bbdd1fe0e3c42522d 4069843(Foam::Ostream&, const Foam::dictionary&)': /home/sajjad/OpenFOAM/sajjad-7/run/HeleShaw/0/alpha.water.#codeStream:53:16: warning: unused variable 'y' [-Wunused-variable] /home/sajjad/OpenFOAM/sajjad-7/run/HeleShaw/0/alpha.water.#codeStream:65:12: error: 'Foam::scalarField' {aka 'class Foam::Field<double>'} has no member named 'writeEntry' /home/sajjad/OpenFOAM/sajjad-7/run/HeleShaw/0/alpha.water.#codeStream:45:13: warning: unused variable 'm' [-Wunused-variable] /home/sajjad/OpenFOAM/sajjad-7/run/HeleShaw/0/alpha.water.#codeStream:46:13: warning: unused variable 'l' [-Wunused-variable] /home/sajjad/OpenFOAM/sajjad-7/run/HeleShaw/0/alpha.water.#codeStream:47:13: warning: unused variable 'x_m' [-Wunused-variable] make: *** [/opt/openfoam7/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/codeStreamTemplate.o] Error 1 --> FOAM FATAL IO ERROR: Failed wmake "dynamicCode/_ea12f2a39247c277bbdd1fe0e3c42522d4069843/platforms/linux64GccDPInt32Opt/lib/libcodeStream_ea12f2a39247c277bbdd1fe0e3c42522d406 9843.so" file: /home/sajjad/OpenFOAM/sajjad-7/run/HeleShaw/0/alpha.water from line 17 to line 17. From function static void (* Foam::functionEntries::codeStream::getFunction(con st Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&) in file db/dictionary/functionEntries/codeStream/codeStream.C at line 215. FOAM exiting Segmentation fault (core dumped) I was wondering if anyone can help me. Thank you |
April 26, 2021, 11:15 |
Rep Power: 5 |
Dear sajjad
I faced a similar problem. did you finally find out the solution? |
libcodestream |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
