Theory behind porousSimpleFoam - where to find citations?
Old   June 29, 2018, 04:04
Default Theory behind porousSimpleFoam - where to find citations?
KTG
Abe
KTG is on a distinguished road
I was wondering if anyone has any references explaining the theory behind porousSimpleFoam? I can see from the source code and this tutorial ( http://www.tfd.chalmers.se/~hani/kur...ukurReport.pdf ) that there is a Darcy term added to the momentum equation. However, I can't find any papers or books to cite that explain why this is a model for porous zones. The papers I have found using porousSimpleFoam don't give a detailed derivation / explanation of the model, or any citations.
Sorry if this thread is out of place here - I couldn't find a better place for theory questions.
KTG is offline   Reply With Quote
Old   June 16, 2020, 14:36
Alejandro
ancolli is on a distinguished road
did u find any citation or book?
Thanks
ancolli is offline   Reply With Quote
Old   June 16, 2020, 15:09
Domenico Lahaye
dlahaye is on a distinguished road
https://books.google.nl/books?id=KzV...0media&f=false
dlahaye is offline   Reply With Quote
Old   June 16, 2020, 16:06
KTG
Abe
The momentum extraction in the openFOAM implementation seems to be just Darcy-Forchheimer. The coefs are in Tensor form though, so search the openFoam user manual for the tensor syntax on that. It seems that these days you can do the same thing with FV options.
Old   June 17, 2020, 12:13
Alejandro
Originally Posted by dlahaye View Post
Thanks, but I do not see the equations used by porous SimpleFoam.
how you go from
U_Darcy = viscous terms + inertial terms
to
N-S = Source (inertial + viscous)
For me it is not clear at all.
Old   June 17, 2020, 12:20
Alejandro
Yes, I saw, and I have tried both approaches, but I have some doubts:
a) Why there is a porousSimpleFoam solver if the porous region can be implemented with fvOptions using any solver?
b) How I should modify codeAddSup in order to allow D and F variable coefficients? in particular, i do not fully understand the coordinateSystem set with regards to the source term: https://openfoamwiki.net/index.php/DarcyForchheimer
thanks in advance
Old   June 17, 2020, 14:18
Domenico Lahaye
Book by de Lemos is a general reference.
Cyprien Soulaine has done a lot of OpenFoam specific stuff.
https://link.springer.com/article/10...242-016-0701-3
Old   June 17, 2020, 19:46
KTG
Abe
That paper looks interesting. With regards to the questions:
a) I am not sure. My guess is that the solvers existed before the fvoptions framework was implemented, and they have stuck around so industry people can use them without doing extra work.
b) I would like to hear the answer to this question as well! I think that #codestream should work for any dictionary entry, so maybe that is something you can try. You might be able to modify the example for setfields to work in this situation:
https://wiki.openfoam.com/Programming1
[Salome] Salome import "Cannot find file "points" in directory..." mismichael OpenFOAM Meshing & Mesh Conversion 5 June 22, 2019 02:56
Coupling with MATLAB via Java, getting the message: "error: cannot find symbol" Dry Patrick STAR-CCM+ 6 October 23, 2018 09:03
/usr/bin/ld: cannot find -llagrangianTurbulence /usr/bin/ld: cannot find -lfluidTherm Luiggito OpenFOAM Programming & Development 9 May 2, 2016 00:54
[swak4Foam] swak4Foam compilation can't find -lOpenFOAM BobR OpenFOAM Community Contributions 4 August 10, 2015 14:49
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
