Unphysical temperature drop when using dynamic mesh
Old   June 18, 2020, 13:07
Post Unphysical temperature drop when using dynamic mesh
peyman havaej
peyman.havaej is on a distinguished road
Dear All
I have recently added an Energy equation to a compressible flow solver developed by myself. It seems that the energy equation is solved correctly on the static mesh; it presents a logical and physical solution.
However, when there is a mesh motion, an unreasonable temperature drop is observed in the fluid domain.
I have tried to debug and fix this issue., therefore, considering the following simplified energy equation:
 fvm::ddt(T) ==fvm::laplacian(alphaThermal,T)
I have set all boundaries and initial conditions to 353K, then it could be logical that temperature remains constant and equal to 353 at the whole of the computational domain. But the temperature has decreased to below 353K.
I have found the unreasonable temperature drop or conservativeness problem is due to the transient term (fvm::ddt(T)).
I have searched for a solution, but I still do not know how I can deal with this problem.
I will appreciate it if anyone has any idea or suggestion about this problem.
Best regards,
Peyman
dynamicMeshDict:
dynamicFvMesh dynamicMotionSolverFvMesh;
solver 		velocityLaplacian;
diffusivity quadratic inverseDistance 1(interface_fluid);
pointMotionU
internalField   uniform (0 0 0);
boundaryField
    interface_fluid
	type            fixedValue;
        value           uniform (0 0.04 0);
  inlet
        type            slip;
        value           uniform (0 0 0);
	outlet
	type            slip;
    bottumWalls
        type            fixedValue;
    topWalls
        type            fixedValue;
    frontAndBack
        type            empty;
T
internalField   uniform 353.15;
boundaryField
   inlet
        type            fixedValue;
        value           $internalField;
	outlet
	type            fixedValue;
    bottumWalls
        type            fixedValue;
    topWalls
        type            fixedValue;
interface_fluid
	type            fixedValue;
        value           uniform 353.15;
    frontAndBack
        type            empty;
peyman.havaej is offline   Reply With Quote
Old   June 24, 2020, 08:35
digger11 is on a distinguished road
Could you find the problem?
I am running a simulation using density-based solver and dynamic mesh in Ansys Fluent, and I also noticed a temperature drop when the mesh moves compared to the static mesh. If I use the pressure based solver then the result is the same for both static and moving mesh.
digger11 is offline   Reply With Quote
conservative variables, dynamic mesh, energy equation, numerical error, openfoam
Dynamic Mesh kennyboy FLUENT 1 February 23, 2019 01:52
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh Emanuele88 FLUENT 0 February 9, 2016 11:39
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 17:00
dynamic mesh for drop interface IndrajitW FLUENT 0 March 30, 2013 08:03
